Gertvr's Avatar
Rotor question for brake experts
There was some discussion on this a while back but i didn't really get a conclusive answer from that, so i am bringing this up again hoping to get some indication as this will be bugging me until i do.....
I bought a set of front and rear drilled rotors (Zimmerman) and the drill pattern on both front and rear rotors are the same for both side's rotors. This means that one side's pattern will spiral out and the other side spiral in with rotation as can be seen below. Is this a problem for normal DD and track days or do I go with what the supplier said that its perfectly fine?
Please let me know what your opinion is about this.
Gert
2008 Honda S2000
2003 C4S (Sold)
1975 911 S with some small modifications
"Its good to plan your work, but its even better to do it"
My Gallery
Old 01-29-2008, 08:24 PM
3.2 CAB's Avatar
I have seen some that are directional, about like the saw-blade or Hurricane type wheels are Left and Right sided. Sorry that this does not help much.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-30-2008, 12:02 AM
haycait911's Avatar
I can't imagine it could make a difference. thinking about it, the only difference is that on one side of the car the arc of each row of holes runs toward the inside of the rotor, on the other side the arc will run to the outside. if that could cause any real difference it's beyond me to see how. and we're talking holes here, not grooves. there's no tendency for a hole to push the pad in any direction on the face of the rotor. FWIW.
Old 01-30-2008, 12:13 AM
Bill Verburg's Avatar
911, 964 use straight internal vanes where the drill pattern is irrelevant
930, 993 use curved internal vanes where the hole pattern is determined by the internal vane structure
Bill Verburg
Old 01-30-2008, 07:19 AM
Your restoration sure looks awesome!!!
Tony G
2000 Boxster S
Old 01-30-2008, 08:39 AM
abit off center
cgarr's Avatar
We drill our own and set them up left and right and also stager the pattern so there are no thru holes.
______________________
Craig
G2Performance
Old 01-30-2008, 08:43 AM
Gertvr's Avatar
Thanks for the responses. Looks like its not going to be a problem.
Gert
2008 Honda S2000
2003 C4S (Sold)
My Gallery
Old 01-30-2008, 09:42 AM
Capitalist and Patriot
911Freak's Avatar
I bought the same rotors for my SC and each rotor was marked Left and Right on the Box, and the hole pattern was side specific...... This was 2+ yrs ago though
Just my .02
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 01-30-2008, 01:13 PM
