-   -   ZDDP. I know this was asked previously. (http://forums.pelicanparts.com/porsche-911-technical-forum/388664-zddp-i-know-asked-previously.html)
WI wide body 01-22-2008 07:55 AM
But what is the recommended amount to add to the oil. Exactly how many ounces to the 12 quarts of oil?
Thanx.
moneymanager 01-22-2008 08:58 AM
It depends of course on what product you are using. EOS? STP? Take a look at the lnengineering.com site...it's all there. If I remember correctly, you need about 0.5 oz of EOS per quart of oil.
wesayso 01-22-2008 09:27 AM
it would depend on the oil you are using to begin with....
If you use Swepco 15W40 or BP 20w50 you don't need to add a supplement like EOS.
WI wide body 01-22-2008 11:28 AM
Adding it to an SM oil that was unfortunately used during the last oil change.
HarryD 01-22-2008 08:28 PM
The answer is in the Ultimate Oil Thread or Why We Hate CJ4/SM Oils.
The best advice is to change the oil again. If the current oil does not have 900-1000 ppm Zn/P, there is no point using an additive.
What oil is there now?
WI wide body 01-23-2008 11:42 AM
Castrol 20W-50W
EarlyPorsche 01-23-2008 12:27 PM
You do not need to change it. To an SM oil a bottle of EOS should have you at or above SL rated oil averages. Don't quote me but that is what I have read over and over so unless something recently changed that will work.
M.D. Holloway 01-23-2008 12:45 PM
You do not want to add any to your oil. Most engine oils have a balenced formula and by adding anything to them may throw off the balence and actually be worse then help. Send me a PM and I'll get ya some of the good stuff - the heck with all this crap from Swepco, Redline, Royal Purple and Amsoil!
dshepp806 01-23-2008 01:37 PM
No additives,...I expect to select the oil from the get-go that has been blended/balanced, providing the Z/P 's within the package itself....my 2 cents....
And I'm damned glad to see the LubeMaster NOT include BP in the "crap" list..!!!
HarryD 01-23-2008 04:22 PM
OK, I'll bite, what's the "good stuff"?
FWIW, I would like to avoid additives as well but I do not think the folks setting the current standards have my needs in mind.
cab83_750 01-23-2008 05:12 PM
sub'd!
WI wide body 01-24-2008 09:22 AM
Wow. Seems to be quite a bit of difference of opinion.
db_cooper 01-24-2008 12:50 PM
I use Rotella T. Dino 15-40 in the summer and Synthetic 5-40 in the winter. Good package of additives and very clean when you remove the covers and adjust the valves. No consumption issues. Try and find the old CI-4 plus or SL in the 15-40. the new "Triple Protection" may not have as much of the good add pack in it.
