2ndTARGA's Avatar
915 Output Shaft Seal In too Far?
I think I just wasted a new (pass. side) output shaft seal by over-exuberantly seating it all the way into the recess of the case until it bottomed out. Now the sealing lip looks too close to the bearing. Then I read this thread where the various insertion tools are mentioned: 915 output shaft seal
Am I right in assuming that the seal should not go all the way in? (The leaky one I took out was flush with the case lip but I'm not sure that was correct either)
Thanks in advance if anyone can comfirm that I need to start over on this and whether the depth can be approximated. (I'm minus a lathe to make a tool)
Thanks,
Ron
1996 993 Coupe, Tiptronic, Polar Silver
1973 914 1.7 Marathon Blue Metallic - Sold
1977 911S Targa - Sahara Diamond Metallic - Sold
1975 911S Targa - Copper Brown Metallic - Sold
Old 02-05-2008, 03:19 PM
DW SD's Avatar
Typically, there is flexibility in depth of such shaft seals. You don't necessarily want it riding on the old groove. That said, you may only move it 1/16" in or out, depending. Sounds like you went too far.
Doug
1971 RSR - interpretation
Old 02-05-2008, 05:11 PM
