I did register. Really not sure I'm ready for the DE. I am going to Roebling Road next Friday. It's such a slippery slope you know.
Let me Know if you need any help with anything. |
How do you subscribe to this thread? Thanks,
Don Ivey '87 Carrera |
Don "click" Thread Tools at the top right of this page. When the drop down menu drops click on subscribe.
S. |
subscribed
"I took the day off from work to pick up the heads. Luckily all valves were good. But I did need twelve new guides. It still added up pretty fats."
Rob - I am anticipating this same project next winter. I know that you posted some costs early on, but based on the scope of your project what would you estimate someone should budget for machine shop work for a similar project? I'm kind of asking what you paid Protech without asking what you paid Protech. Thanks. |
If your valves and springs are still good, and you only need valve guides, I think $700.- to $1000.- to do the heads.
It would include checking the springs, measuring the valve stems, installing new guides, 3-angle grind and shaving off ~0.002 equally from the heads. Most important is to find a shop with experience and a good reputation. Depending on Mileage and condition, other machining could show up when disassembling. Hope you'll find Mahle P/C's. |
The work on my heads came in a few dollars over $1,000. That covered, 12 guides, 12 additional shims, new seals, valve job, cleaning, plus surfacing the flywheel. (Labor rate was $88/hr.) So the total cost for replacing the guides, the divlar studs, new tensioner oil lines, all accessible seals/gaskets, and other general minutia (Minutia may be a misnomer. Those "small" items add up fast when they’re Porsche parts): $2,500. |
Rob,
I am also starting a rebuild soon. In fact, I am waiting on you to finish so that I can use Kevin's stand! :) My "spare" engine is being delivered tomorrow. Can't wait to dig in. A few posts back you included your expenses to date. It would be great if you could keep posting that info every week or so with the breakdown - it certainly helps others get a better idea of costs involved. Is $2500 your total so far? Also, were you satisfied with Protech? I will likely send my heads to them as well since they are geographically closest to me - should save a little on shipping. Many thanks and thanks for starting this thread. Craig |
Sure Craig,
But the list is getting pretty long. Especially when you factor in the clutch project. :rolleyes: |
Craps ... that reminds me. I need to add a new clutch to my Projects List.
Sure does add up fast! You have enough on your plate with your rebuild - don't worry about compiling a list of expenses. Maybe after you finish and have some free time. |
Qty Price Cost Part 4 $1.50 $6.00 911 CV Joint Bolt 1 $81.75 $81.75 Reverse Light Switch 1 $72.00 $72.00 Cam Bar tool 1 $25.20 $25.20 Heat Exchanger Nut Removal Tool 1 $54.25 $54.25 Thermo valve 1 $163.19 $163.19 Fuel line 4 $4.00 $16.00 Ball Socket Retaining Clip 1 $1.20 $1.20 Cable Holder 2 $97.00 $194.00 Position Sensor, Motronic Ignition 1 $73.75 $73.75 Temperature Sensor 2 $7.50 $15.00 Chain Ramp 24 $4.50 $108.00 Rocker shaft RSR seals 1 $27.00 $27.00 Cam oil line RH 1 $46.00 $46.00 Cam oil line LH 1 $19.75 $19.75 Pulley Seal 1 $218.00 $218.00 Cylinder gasket kit 12 $13.50 $162.00 Head studs 4 $12.75 $51.00 Oil return tubes 6 $0.50 $3.00 Copper exhaust nuts 6 $3.00 $18.00 Exhaust barrel nuts 1 $9.00 $9.00 Assembly Lube 1 $4.25 $4.25 Converter to muffler seal 1 $9.00 $9.00 Mahle oil filter 1 $30.00 $30.00 Case sealers, thread lockers 12 $3.00 $36.00 Brake cleaner 1 $7.00 $7.00 Mineral Spirits 1 $51.00 $51.00 Resurface G50 flywheel 6 $160.00 $960.00 Machine work (12 guides, 12 shims) TOTAL $2,461.34 |
Clutch project:
Qty Price Cost Part 1 $186.25 $186.25 Improved shaft & Bushings 9 $1.50 $13.50 Pressure plate bolts 1 $28.00 $28.00 Throttle shaft arm 1 $50.00 $50.00 Clutch slave line 1 $6.50 $6.50 Engine Oil Switch 9 $2.00 $18.00 Flywheel bolts 1 $304.25 $304.25 Clutch disk 1 $8.00 $8.00 Pilot bushing 1 $409.00 $409.00 Pressure Plate 1 $113.00 $113.00 Throw out bearing 1 $202.00 $202.00 Improved release fork 1 $89.00 $89.00 Slave cylinder 1 $71.00 $71.00 Throwout guide tube 1 $12.50 $12.50 Mainshaft seal 1 $13.00 $13.00 Shift seal 1 $14.50 $14.50 Flywheel seal 1 $1.75 $1.75 Engine int. shaft seal 1 $8.85 $8.85 Clutch align. tool TOTAL $1,549.10 |
Great! Thanks for taking the time to put that together.
Good list. :)
6 $160.00 $960.00 Machine work (12 guides, 12 shims) What shims are those? |
Whatever works at the time I suppose. |
If it isn't excessive, the extra amount sticking out is absorbed by the adjusting screw. :confused: To be clear: 12 new thicker OEM shims? Do these shims come with various thickness? Or adding shims to the existing ones? Please, clarify. SmileWavy |
I discussed the issue of how the stems stick out a little more after grinding the seats and was told that the adjuster screw will absorb it. That made sense to me but there may be something new to learn. 12 new OEM shims? Why? Or what exactly, please. SmileWavy |
If the spring is less compressed as the stem moves out, then there will be less preload on the spring and less force required to open the valve? ianc |
| All times are GMT -8. The time now is 03:11 PM. |
