87 Brake Pad styles
I am replacing the brake pads on a 1987 Carerra Targa and need clarification on pad styles. Apparently there are 2 types of pad for this yr, a notch style and a glue on style for the wear sensor. Before I order the wrong pad, could someone please confirm if the picture attached is the glue on style. There is a small diameter hole in the top of the pad into which the sensor plugs in.
Also, the guy who owned the car previously used some type of adhesive on the pad and they are really stuck to the calipers. Any suggestions on removing them with the least possibility of damage to the caliper. Is it safe to stick a small putty knife in thru the back side of the pad to break the adhesive loose?
Old 02-06-2006, 04:55 PM
GFCC
Jeff's Avatar
Mine look different. They have a "U" shaped / half moon cut out in the top of the pad backing plate. I think yours are the glue in type.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 02-06-2006, 05:15 PM
GFCC
Jeff's Avatar
Oh, Welcome to the board.
Jeff
Old 02-06-2006, 05:16 PM
Yes a putty knife is safe. The caliper is a pretty solid hunk of metal so your not going to damage it by prying against it. I have the U shaped cutouts like Jeff described on my 87. I've never seen this glue in kind. Finally, the sensor pads are delicate and break easy. I don't even hook mine up and tie wrap them back against a hard brake line or something secure. I have my wheels off enough to check the pad wear without the sensors.
Kevin
'87 Targa
Old 02-06-2006, 06:04 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
are you sure you arent talking about bonded versus riveted?....This I have heard of....but never heard of glue in brake pads....on any type of car.....bonded pads are "glued" to the backing plate versus riveted....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 02-06-2006, 06:12 PM
syncroid's Avatar
Re: 87 Brake Pad styles
[QUOTE]Originally posted by tomjura
[B]I am replacing the brake pads on a 1987 Carerra Targa and need clarification on pad styles. Apparently there are 2 types of pad for this yr, a notch style and a glue on style for the wear sensor. Before I order the wrong pad, could someone please confirm if the picture attached is the glue on style. There is a small diameter hole in the top of the pad into which the sensor plugs in.
The pads you pictured are the glue-in type. Meaning that the sensors are glued into the pads. NOT the pads glued to the pistons and dust boots! The factory pads are superceded to this type of pad. You can still get the "U" shaped sensor type pads though. The only difference is the sensors themselves.
Yes, a putty knife (used carefully) will work. I hate that when people glue the pads in. All it ends up doing is ruining the dust boots for the next guy (like you) that has to do a pad replacement.
Good luck and welcome to the board.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 02-06-2006, 06:13 PM
Thanks all. Great advice. I'll be back:>
Old 02-06-2006, 06:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Question, What type of glue does one ues? Can't find it on host's site.
'85 Carrera Targa
PCA/POC
Old 01-22-2008, 04:50 PM
syncroid's Avatar
I just use 3M weather strip adhesive in a tube. Seems to do the trick.
Dan
Old 01-23-2008, 10:18 AM
