Guest
Posts: n/a
1994 C4 964
Once or twice a week, many lamps on the dash will flash and go dim ( radio will turn off for a brief moment ) and the engine will start to die or die. It will start back up without any problem. One another thing, my radar detector will display 'low voltage'. I checked the battery ( battery about 3 months old ) and it's putting out 12.6 volts ( engine off ). With the engine running it's 13.5 volts. Question: Do you think the Alternator or the Voltage Regulator is going out or more likely poor Ground connection somewhere? |
Guest
Posts: n/a
Check out Rennlist.com in the 964 section.
Or your dealer. Apparently there was some sort of recall regarding the clock connector board failing/poor connection, causing this condition. Of course, I with an 85, didn't read this completely. Good luck. Nick |
