Bob Smith
Guest
Posts: n/a
Red face Electrical problems 964?
1994 C4 964
Once or twice a week, many lamps on the dash will flash and go dim ( radio will turn off for a brief moment ) and the engine will start to die or die. It will start back up without any problem. One another thing, my radar detector will display 'low voltage'.
I checked the battery ( battery about 3 months old ) and it's putting out 12.6 volts ( engine off ). With the engine running it's 13.5 volts.
Question: Do you think the Alternator or the Voltage Regulator is going out or more likely poor Ground connection somewhere?
Old 04-03-2001, 11:30 AM
nhromyak@yahoo.com
Guest
Posts: n/a
Post
Check out Rennlist.com in the 964 section.
Or your dealer.
Apparently there was some sort of recall regarding the clock connector board failing/poor connection, causing this condition.
Of course, I with an 85, didn't read this completely.
Good luck.
Nick
Old 04-03-2001, 01:14 PM
