Bruce Johnston
Guest
Posts: n/a
Post Bouncing Tach
I just bought a 82 911 SC with 136,000 (1st Porsche) which runs great and has good records. Last night after I got on it a bit getting onto the freeway I noticed about 15 miles later the Tach needle was bouncing about 1500 rpm each bounce, but the engine was running smooth. The engine quit at a stop light. It started right up and about 2 miles more as I was pulling over to stop. The engine quit and all the power was gone (like the battery was disconnected). I checked the fuses and battery, which were good then tried the key again. It started so I parked it. 2 hours later I went home and everything was normal. Anyone have any ideas?
Old 04-04-2001, 11:01 PM
Tlook
Guest
Posts: n/a
Lightbulb
The coil runs your tach, and also gives your distributor power so it can fire the cylinders. I'm thinking you have something loose on the coil--ground wire?--or the coil may be going bad as it gets heat soaked after driving it awhile.......again.....it's just a maybe.....
Old 04-05-2001, 04:09 AM
Huey581
Guest
Posts: n/a
Post
Bruce!
Had a similar problem with my 86' 911 last year. It ended up being a coroded ground strap from the battery that was not grounding the car properly. $ 11.00 dollars later with a new strap the problem was fixed!
Good Luck!
Huey581
86' 911 Cab
Old 04-05-2001, 04:26 AM
