993 Engine Swap
I was wondering if it would be possible to mount a 993TT engine to a two wheel drive 993 transaxle (6 speed). I heard that the turbo and NA cases are so completely unrelated that they cannot be mounted to the other trans. Would this leave me having to look for a GT2 trans? Any thoughts would be greatly appreciated.
Old 01-26-2008, 06:27 PM
993TT and 993NA use the same basic case so I dont see any problems with bolting a 993 6 speed to it. It should all be bolt up
Old 01-26-2008, 06:57 PM
Bill Verburg's Avatar
All 993 variants use the same block and lower end. so yes a 993tt can use a n/a 993trans.
It's the 996, Bosxter, and Cayman engines and trans that are incompatible w/ the GT3, tt, 993
Bill Verburg
Old 01-26-2008, 07:09 PM
I must have read about 996 engines then.
Old 01-26-2008, 09:27 PM
You can actually fit a 996 GT3 CUP engine on a ....boxster. Its been done
Old 01-27-2008, 05:35 AM
Yes, but you use an upside down GT3 trans to do so
Bill Verburg
Old 01-27-2008, 09:06 AM
