911S distributor ID?
Hello Pelicanites,
I have a 914-6 that I'm rejuvinating, and I hit a road block tonight. I've been ticking off the list of tasks to be done this weekend. I R&R'd the Webers with a mini-rebuild, adjusted the valves, and a couple of other little things. Went to install the new points/rotor/cap I've had for a couple of weeks and the dang things wouldn't fit. Unfortunately I threw away the old cap a few weeks ago, which I'm guessing at this point may have been a mistake.
It was getting pretty late, and I needed to clean up and get outta the garage, so I didn't pull the dizzy. But using an inspection mirror, I was able to read the numbers 0 231 159 002. I'm not entirely sure on the bolded part, but it from the last 45 mins of searching here I'm guessing that's correct.
The plate is black, and there was a 050 in the upper left-hand corner of the plate. I'm guessing that would make this the 050 black plate 0 231 159 002 I saw referenced in a thread with a yellow plate 002.
I know the engine has a few goodies in it, but not the exact details from searching, it looks like this is a 911S dizzy? Is that correct? If so from what year? P/N for cap and rotor?
Thanks for any information.
Adam
Old 03-04-2007, 10:15 PM
0 231 159 002 is the distributor from a '67 911S.
Points are 2-piece part number: 901.602.960.03
I don't think the early caps are readily-available - you need to modify the later cap part number: 911.602.933.00
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 03-05-2007, 10:50 AM
Thanks for the info, that might be the cap I have, and it just needs a trim.
Thanks,
Adam
Old 03-05-2007, 11:55 AM
Bland
unclebilly's Avatar
Is there a data dump somewhere on distributor part numbers and applications?
I am trying to find the part number for the correct distributor fpr a 2.4S or 2.7RS.
Is 0 231 169 008 the distributor for a T or an S? What about 0 231 184 003? How about 0 231 184 004?
Old 01-26-2008, 07:39 AM
Bland
unclebilly's Avatar
Here is what I found:
0 231 121 006 -’65 -‘67 except for the S
0 231 159 001 -‘67 2.0 L and T
0 231 159 002 -‘67 2.0 S (VERY different curve)
0 231 169 001 -‘68 2.0
0 231 159 006 -’69 -’71 2.0/2.2E
0 231 159 007 -’69 -’71 2.0/2.2S
0 231 159 008 -’70 -’71 2.0/2.2T
Anybody have any data on the 2.4 liter cars?
Old 01-27-2008, 07:25 AM
Bland
unclebilly's Avatar
And my 77 911S 2.7 has 0 231 184 007.
Old 01-27-2008, 07:19 PM
andrew15's Avatar
unclebilly:
The 2.4 distributors are:
T: 0 231 169 003
T: 0 231 169 008 (73.5 T w CIS)
E: 0 231 169 004
S: 0 231 169 005
RS: 0 231 169 011
I think the '169' changed at some point to reflect different orientation of the points, but the above numbers are from a Porsche spec book
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 01-27-2008, 07:50 PM
gungadin's Avatar
Are you sure that's not 001...?
'76 911S w/ '79 3.0 SC engine. Irish Green
Old 01-27-2008, 09:12 PM
jasam's Avatar
Cool info, great to know...
See you M8s
There is no substitute
Old 01-28-2008, 07:23 AM
Bland
unclebilly's Avatar
Yup, I just checked it again.
Old 01-29-2008, 05:55 PM
