Retired Member
Brian 162's Avatar
14 Pin Connector
While correcting some wiring issues the 14 pin connector broke in one corner. I'm thinking of using spade connectors to join the one affected connection.
Pelican web-site says connector is NLA.
Does anyone know where I can make something that would work? I'm not concerned about originality.
Here is a picture of the connector.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 01-13-2008, 05:27 PM
Warren Hall Student
Bobboloo's Avatar
Find the missing piece and epoxy it.
If you can't find the missing piece then just press the male pin #1 into the female pin #1 of the 14-pin connector on the fuse panel. No need to change to a spade type connector.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 01-13-2008, 05:40 PM
Rob Channell's Avatar
If you do decide to replace it, the Anderson PowerPole connectors look pretty nice.
http://www.andersonpower.com/products/singlepole-connectors.html
I have had a similar problem with my DME relay. I can replace the connector..........by buying a replacement wiring harness (groans at the thought).......
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 01-13-2008, 09:45 PM
David's Avatar
I bought a new one from Zims a year ago, maybe they still have some.
Old 01-14-2008, 05:50 AM
DW SD's Avatar
I bought one from Pelican which was a 964 or 993 part.
Or get one from a salvage yard. It will be cheap.
Doug
1971 RSR - interpretation
Old 01-14-2008, 08:02 AM
Retired Member
Brian 162's Avatar
Thanks for the advice guys . I now have some options when I re-assemble the harness.
Brian
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 01-14-2008, 06:55 PM
Network Native
Danglerb's Avatar
Pet6 show the part number as "911 612 113 05" and google gave me a hit at Patrick Motorsports for $37 (new body and pins).
http://www.patrickmotorsports.com/part/144/
and 928 Specialists.
https://www.928gt.com/s-247-frontbody.aspx
Old 01-28-2008, 10:18 PM
Recreational User
DarrylD's Avatar
Just go to a junkyard and find any 924, 928 or 944 wreck, they're full of this type of connector and not highly coveted wiring harnesses.
Old 01-28-2008, 10:40 PM
