rear bumper rubber
I would like to replace the rubber strips on my rear bumper (thick rubber strips at the corners of the bumper) and I noticed that the left part costs three times as much as the right part. They appear to be identical. Anyone know why there is such a big cost difference? The car is an '88 Carrera.
Thanks,
Bob
Old 03-12-2006, 03:52 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
Gee....that question sounds just like the one I posted a month ago...lol....there are no real differences although the parts are not interchangable...I was lucky enough to find a used set from a pelican member who sold them very reasonable...They are at home waiting for my arrival...I have a set that will need a little modification to make work (the mounting screw on the left inbord strip had corroded badly) otherwise the strips are virtually perfect...let me know if you want them...would be about the cost of the right one shipped if I remember correctly for both...but it may be a week or two before I am home....out of town on business...
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 03-12-2006, 04:00 PM
Formerly bb80sc
Vipergrün's Avatar
Just take them off and use plugs for the holes.....oh, and you can remove those HUGE bumper pads too, plug the holes, for a much cleaner look and some good weight savings....
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 03-12-2006, 09:52 PM
oly oly is offline
1985 Carrera Coupe
I'd like to know the answer to this question too!
I'll bet the answer is because the demand is higher for the left one. My left one looks fine from the outside but the mount bolt corroded and so it does not fit flush with the bumper (same problem as stormmaster). The corrosion probably happened only on this side because it sits right above the muffler and gets soaked in the corrosive exhaust gasses. My right one looks fine AND the mount bolt is okay.
Art
Old 01-26-2008, 11:16 AM
3.2 CAB's Avatar
The difference in prices between left side parts and right side parts is on many items. Check the prices for the Carrera style fog lights. Very few places have the same price for both left and right sides, usually the left side parts are at a premium cost. I guess that there is a larger profit margin to be made on the left side parts, possibly due to those parts get damaged more times than the right side parts. Just my $0.03
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-26-2008, 11:42 AM
The left side has a tow hook hole. Apparently the extra 2 seconds to drill a hole during the manufacturing process is extremely detailed.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-28-2008, 09:25 PM
