cutting speed for lathe on PG bushings
Hi Souk and The,
Thanks for the interesting discussion on the PG bushings ;-).
(I'm an automotive engineer performing FEM-analysis on rubber (tires) so could run some simulations ;-)
I guess that both ways have there pro's n con's, however measuring my front clamps for the A-arms wiv digital caliber shows that they are quit round. 50.4 mm. and perpendicular to this value I measured 50.3.
I figure that the flow of material into the direction of the bolt holes of the clamps will be negligible, however I don't have any material data like E-modulus and viscoelastic data like tan.delta....
Now my question that both of you hopefully can answer. What is the cutting speed (rev's /min.) for the machining of the PG bushing material?
Regards,
Bart
Old 03-11-2008, 03:11 PM
Zeke's Avatar
I'm not Souk or The, but I cut plastic rather fast. You don't want to cut deep and slow where the plastic gets hot and rebonds to the cut. Shallow and fast would be my choice.
Old 03-11-2008, 06:46 PM
