Puny Bird
Mark Henry's Avatar
Which fan/alt should I use, and a quick wiring?
I have two of everything, one is I believe a '69 and the other a '75.
The one fan is for sure Bosch, shallow depth, so 55amp right?
The other has no manufactures label and is the deep depth. Do you know what brand it is?
I have 2 fan pulley haves one small and one bigger, whiich one should I use?
Also I won't be using the accessory pulley part of it, so can I cut that bit off? or should I leave it alone?
Wiring it has two terminals of almost eveything (the bosch unit only has two B+'s) do I just jumper these together?
And finally do I just use the bosch external regulator on both these units?
Going on a 914 3.0 conversion, hoping to sell the one I don't use once I know the other works well....or should I just keep it for a spare?
thanks
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-03-2013, 09:09 AM
