(the shotguns)
berettafan's Avatar
Need to borrow/rent schutz gun
Need to borrow or rent a Wurth schutz gun (need the schutz as well if you have any unopened).
Damon from series900 had offered one up but i can't seem to get in touch with him.
Thanks to any who can help.....
Erik
Old 01-29-2008, 11:09 AM
burgermeister's Avatar
You must have gotten your pan in at last!
I went the cheesy Eastwood undercoat route. The seam sealer I used was some product by Lord that I bought at an auto paint store - beige, and according to instructions could be used a caulk (my usage) and also be sprayed as undercoat. Dried to a similar consistency as the factory stuff. I Imagine the auto paint store would rent the equipment.
Still, fantastic that you're going the factory original route. Good luck!
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 01-29-2008, 02:53 PM
Will PM you.
Old 01-29-2008, 03:45 PM
(the shotguns)
berettafan's Avatar
burger i sure did!
if you look on the paint/body forum there is a post by a guy who used the SKS INSIDE of his trunk and the look is fantastic.
Old 01-29-2008, 03:58 PM
(the shotguns)
berettafan's Avatar
here's the car in question; it belongs to 'drm05'. fantastic looking finish IMO.
Old 01-29-2008, 04:22 PM
(the shotguns)
berettafan's Avatar
burger i went with eastwood seam sealer and was kinda surprised by the consistency. not the easiest stuff in the world to work with. i'll put a nice long 'project' post up when i'm done with the pan and have some time to put the pics and such together.
Old 01-29-2008, 04:26 PM
Series900's Avatar
your email was in the monty python directory, found it this morning as I was deleting, offer still stands
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 01-29-2008, 08:12 PM
Bland
unclebilly's Avatar
These are cheap (like $50) - even here in canada. Try autozone or napa. You do not need a wurth one, they are all about the same. Play with your air pressure to get the desired consistancy.
Old 01-29-2008, 08:18 PM
I look forward to the post! (And to spring ... seems soooo far away)
Old 01-30-2008, 02:37 AM
Slumlord
Porsche_monkey's Avatar
Mine was under $20, and it works great.
Old 01-30-2008, 05:34 AM
I have the two styles by Wurth that you can use. Let me know if you still need.
Warren & Ron, may you rest in Peace.
Old 01-30-2008, 07:32 AM
If you are using the Wurth product you need the Wrurth gun to screw on to the over sized threads on the can.
If you are going with the SKS series product you can use either gun but if you go with the underbody seal then you need the Shutzu gun..
LM
Old 01-30-2008, 03:21 PM
(the shotguns)
berettafan's Avatar
Thanks all; Dana email sent. It looks like Dana has the underbody seal which i will use on the....underbody! I think i'll be ordering some SKS as well to put on the inside as per 'drm05' in the pic above.
Old 01-30-2008, 06:57 PM
Berettafan, while you're most likely already thinking of this, be sure to tape something over the fuel tank hole when applying the underbody coating. You can probably guess how I came by my knowledge of this little trick. It wasn't by spending 2 seconds thinking about what I was doing ...
Old 02-01-2008, 04:02 AM
(the shotguns)
berettafan's Avatar
****....i would not have done that. i'm so damn anxious to get her coated and back on the ground...
thank you VERY much for pointing that out!!!
Old 02-01-2008, 05:55 AM
robmog's Avatar
floor pan
we haven't seen pictures in a while!
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 02-01-2008, 07:51 AM
