nicfranc's Avatar
Triangle of death
I am working in the "Triangle" and am installing the Case Breather Gasket.
Is this installed dry or do you apply sealant as well ?
I have discovered that I have an oil leak in this area but do not know which component is the culprit or if they are all contributing.
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 09-10-2013, 03:00 PM
porsher
aston@ultrasw.c's Avatar
I used the best sealant I could find.
Cleaned both surfaces with acetone and clamped it down gently.
Come to think of it, i don't think I used the gasket...
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 09-10-2013, 03:13 PM
Northern Motorhead
wildcat077's Avatar
I installed mine dry on two different engines ... you might want to cut two inches off the bottom of the breather hose as it hardens at the clamp area and has a tendency to crack eventually and replace your oil sender switch while you're there !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-10-2013, 03:49 PM
nicfranc's Avatar
Breather Gasket ….Dry or Sealant ?
I was wondering since this area is such a problem are people using a Pematex like sealant on both sides of the gasket
Old 09-10-2013, 07:29 PM
pete3799's Avatar
I put mine on dry....no problems.
Pete
79 911SC RoW
Old 09-10-2013, 07:52 PM
dsmyth's Avatar
Phil's point was good. I usually find it's the breather hose that does the most damage/leaking. If the hose appears at all hard ,replace it. Clean all surfaces well. Use a small amount of gasket sealant on both sides of the breather gasket. Repeat small amount. Good luck
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 09-10-2013, 08:22 PM
Hell Belcho
Nostril Cheese's Avatar
A bit of Curil T on the gasket won't hurt, but yeah, if the surfaces are clean, it should be fine dry.
Old 09-10-2013, 08:56 PM
nicfranc's Avatar
Breather Hose
I purchased the lower oil breather hose from Pelican and they sent a braided fabric hose.
Is this the correct hose or should it be rubber ?
I have seen both used just wondering if their is a difference.
I also purchased the top hose that also goes to the oil tank neck and this one is rubber.
Old 09-10-2013, 09:03 PM
Northern Motorhead
wildcat077's Avatar
I replaced the breather hose with a braided fabric one when i installed the 3.6 in my car,it's probably cheaper to replace as it's a generic 1 inch heater hose which will do just fine !
Cheers
Phil
Cheers
Phil
Old 09-11-2013, 04:06 AM
I have just dealt with this I installed mine dry but did sand down the very rough sealing surface that was on my cover first.
I think my biggest leak was from the thermostat o- ring failing. The thermostat came right off but made a suction noise and was much tighter when re installing with a new o-ring.
Cheers
Bill
1977 Carrera 3.0
This much fun must be illegal!
Old 09-11-2013, 04:23 AM
nicfranc's Avatar
Oil leak prevention oil breather gasket
I think after inspecting the area the most likely culprit was the O-Ring on the Thermostat.
I do not want to be doing this again anytime soon so I would like to make sure the breather does not leak.
I guess I should replace the oil cooler rubber seals as well while I have the engine partially dropped and the CIS removed.
( I thought I was in the assembly mode but now I might have to regroup and get these seals installed)
Has anyone removed the oil cooler with the engine in car ?
Old 09-11-2013, 07:14 AM
Dry is fine. Remember guys, our engines are now close to 30 years old, and god only knows how old the current gasket is. So by replacing these three items, you will be light-years ahead as far as leakege is concerned. I did mine last year, and my engine is dry as a bone.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-11-2013, 07:49 AM
thin coating of Loctite 574 on both sides of the gasket
Old 09-11-2013, 08:32 AM
theiceman's Avatar
Dry ... no issues .. check those bushings on the throttle linkage while you have it out ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-11-2013, 10:00 AM
muck-raker
kidrock's Avatar
isn't there supposed to be a difference between the green o-ring and the red o-ring for the thermostat? IIRC, a lot of members were recommending one over the other due to leakage issues.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-11-2013, 10:06 AM
nicfranc's Avatar
O Ring on T Stat
I read the same thing about the Red -Ring so put the green one in and I also put new bushings in the throttle lever.
Old 09-11-2013, 10:19 AM
NOLAsc's Avatar
Do others concur here that green is the way to go for Thermostat o-ring? That answer hard (at least for me) to find in search. (Not trying to highjack, just thought this would help folks.)
Also, does anybody recall someone's hint to coat the new pressure switch with some kind of sealant?
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 12-05-2013, 12:02 PM
Another tip for this is to make sure the breather is straight before reinstalling, place a piece of fine sand paper on a flat surface and run the breather over it and make sure it has no dips and valleys, sand it down until its completely flat to ensure a nice sealing surface, than no need for sealant.
Alex
____________________
1977 Porsche 911S (Daily driver)
1972 Porsche 914-6 GT Clone (Project)
Old 12-05-2013, 02:47 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Thumbs up
Yup... I did the same. Never want to go back in for this...
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 12-05-2013, 03:15 PM
Sand the breather cover with Silicon Carbide wet/dry sandpaper in the 200 range on a piece of 1/4" glass, or the top of a cast iron table saw. Wet paper with WD40 and sand in a circular motion. Do this until the whole mating surface is flat with new metal showing.
Bob B
Old 12-05-2013, 03:18 PM
