-   -   o2 sensor question (http://forums.pelicanparts.com/porsche-911-technical-forum/390486-o2-sensor-question.html)
jinos 02-01-2008 10:55 AM
o2 sensor question
Hi guys. I just bought a test pipe and the o2 plug is capped off. My 83 3.0 motor has an o2 sensor and was wondering if it will make a big difference if I run without one. Will this effect the way my engine runs (good or bad)? Sorry if it's a dumb question. Thanks.
Bill Verburg 02-01-2008 11:02 AM
The engine will just go into open loop mode, mpg will probably go down a bit, some say there is better throttle response but not that IO could detect.
Persinally I would leave a functiong O sensor in the loop
DRACO A5OG 02-01-2008 12:07 PM
You may have starting and hunting issues as well and if in Cali you will not pass smog.
jinos 02-01-2008 12:43 PM
Car is a 74 which is smog exempt. :D
jinos 02-01-2008 12:44 PM
nice steel conversion too! http://forums.pelicanparts.com/uploa...1201898684.jpg
DRACO A5OG 02-01-2008 02:15 PM
Smog Exempt, Sweet. 74 I think you can get a Antique Plates so you only have to register every 5 years, again Sweet.
BTW, Nice A$$ on the Baby :D
