o2 sensor question
Hi guys. I just bought a test pipe and the o2 plug is capped off. My 83 3.0 motor has an o2 sensor and was wondering if it will make a big difference if I run without one. Will this effect the way my engine runs (good or bad)? Sorry if it's a dumb question. Thanks.
The engine will just go into open loop mode, mpg will probably go down a bit, some say there is better throttle response but not that IO could detect.
Persinally I would leave a functiong O sensor in the loop
Member 911 Anonymous
You may have starting and hunting issues as well and if in Cali you will not pass smog.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Car is a 74 which is smog exempt.
nice steel conversion too!
Smog Exempt, Sweet. 74 I think you can get a Antique Plates so you only have to register every 5 years, again Sweet.
BTW, Nice A$$ on the Baby
