Send a message via AIM to Ag02M5
Material needed for custom suspension gasket
Hi.
Hoping someone can direct me to the proper material.
I am looking to add coilovers with camber plates to my 965.
I would like to put a very thin rubber gasket in between the mount and the fender to try to keep noise as low as possible. Something similar to the stock ones.
Now I know I want something very thin that does not allow for play in the mount. I am thinking like CD thin. I want to avoid the metal on metal.
I looked at the autoparts store and found some bulk roll gasket material but it certainly wasn't the type of rubber found in suspension components. I would like to find something that can stand up to the abuse.
Any recommendations would be aprreciated.
Cheers.
RT
Good ending to the Super Bowl I must say.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 02-03-2008, 09:23 PM
Danny_Ocean's Avatar
Industrial-strength rubber floormats (the kind they use under machinery, flooring)...
Old 02-03-2008, 09:31 PM
Better yet, use a urethane material with a 53-57 durometer.
Thats FAR more durable than any rubber,...............
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-03-2008, 10:21 PM
I was also thinking something like that.
Any ideas as to where one might find a thin sheet of it or where someone could get a set cut?
Cheers.
RT
Old 02-04-2008, 07:08 AM
Aircooled Breakfast
Go to McMaster-Carr (mcmaster.com) and search for "rubber sheet". From there you can sort by many variables. Hope this helps.
John
Old 02-04-2008, 07:32 AM
