-   -   Rust! But this is SoCal... (http://forums.pelicanparts.com/porsche-911-technical-forum/391829-rust-but-socal.html)
slodave 02-08-2008 07:00 PM
While I had the passenger door open, I decided to peel back the black rubber strip on the door sill. I had lifted it on the drivers side a couple of times and didn't see any rust. The passenger side was not so lucky, but, it's not bad. I'll clean it up and put a little RustOleum over the spot and things should be OK. There is a little divot, but it does not go all the way through.
http://forums.pelicanparts.com/uploa...1202526026.jpg
http://forums.pelicanparts.com/uploa...1202526035.jpg
http://forums.pelicanparts.com/uploa...1202526046.jpg
SmileWavy
450knotOffice 02-08-2008 07:13 PM
Use a stainless steel stripping wheel on that spot, Dave, and clean it up so that there's nothing but clean metal there. POR it and paint it over and you should be good to go.
Btw, I PM'd you about Mammoth.
slodave 02-08-2008 07:16 PM
I'll get creative with the Dremel. The spot is small and a wire wheel will take too much surrounding off.
Read the PM. I have no firm answer yet. I'll bring it up with my dad again tonight.
Dave
450knotOffice 02-08-2008 07:17 PM
Dude, jump in your car and DRIVE up there if you have to. ;)
I'm checking the weather but if it's forcast to stay good, I'm bringing the 996 up there. ;)
the 02-08-2008 07:24 PM
I think the glue sometimes lifts the paint, leaving the metal exposed under there. Then water gets caught under the rubber strip.
porsche930dude 02-08-2008 07:31 PM
Your car is too nice. You need a rust spot or two your making our cars look bad :)
450knotOffice 02-08-2008 07:35 PM
You should see his car in person! In sunlight the color is amazing.
DRACO A5OG 02-08-2008 08:27 PM
Not Bad for being 24, She's still a PYT
khamul02 02-08-2008 09:35 PM
Awesome Color!
slodave 02-08-2008 10:34 PM
Thank you, you all are too kind.
No worries, there is other rust, but mostly due to a battery exploding - I did clean and repaint the area though. I'm sure rust is hiding in other places, but living in a dry climate does keep it to a minimum.
Jim, this area is a rust haven. So, while you are taking your DME apart to resolder, you might as well check these areas on your car too. ;) Also the Arena Red, was done in '96. You can see the OEM color peeking through in the door sill shots.
Dave
rnln 02-09-2008 03:23 AM
Dave,
I can't see/analyze the pics very well. Are those gray areas the metal (expose because the paint is pulled up) or are they the ground I am seeing through the holes? Whatever they are, I would take care of them. If it's just the paint you are lulling up, simple. If it's the holes, I would cut them off and patch them somehow.
Good luck.
crashmy911 02-09-2008 06:23 AM
Rust bucket. Part it out!
