slodave's Avatar
Rust! But this is SoCal...
While I had the passenger door open, I decided to peel back the black rubber strip on the door sill. I had lifted it on the drivers side a couple of times and didn't see any rust. The passenger side was not so lucky, but, it's not bad. I'll clean it up and put a little RustOleum over the spot and things should be OK. There is a little divot, but it does not go all the way through.
Old 02-08-2008, 07:00 PM
450knotOffice's Avatar
Use a stainless steel stripping wheel on that spot, Dave, and clean it up so that there's nothing but clean metal there. POR it and paint it over and you should be good to go.
Btw, I PM'd you about Mammoth.
Old 02-08-2008, 07:13 PM
slodave's Avatar
I'll get creative with the Dremel. The spot is small and a wire wheel will take too much surrounding off.
Read the PM. I have no firm answer yet. I'll bring it up with my dad again tonight.
Dave
Old 02-08-2008, 07:16 PM
Dude, jump in your car and DRIVE up there if you have to.
I'm checking the weather but if it's forcast to stay good, I'm bringing the 996 up there.
Old 02-08-2008, 07:17 PM
the the is offline
I think the glue sometimes lifts the paint, leaving the metal exposed under there. Then water gets caught under the rubber strip.
Old 02-08-2008, 07:24 PM
Your car is too nice. You need a rust spot or two your making our cars look bad
Old 02-08-2008, 07:31 PM
You should see his car in person! In sunlight the color is amazing.
Old 02-08-2008, 07:35 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Not Bad for being 24, She's still a PYT
'85 Carrera Targa
PCA/POC
Old 02-08-2008, 08:27 PM
khamul02's Avatar
Awesome Color!
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-08-2008, 09:35 PM
slodave's Avatar
Thank you, you all are too kind.
No worries, there is other rust, but mostly due to a battery exploding - I did clean and repaint the area though. I'm sure rust is hiding in other places, but living in a dry climate does keep it to a minimum.
Jim, this area is a rust haven. So, while you are taking your DME apart to resolder, you might as well check these areas on your car too. Also the Arena Red, was done in '96. You can see the OEM color peeking through in the door sill shots.
Dave
Old 02-08-2008, 10:34 PM
rnln's Avatar
Dave,
I can't see/analyze the pics very well. Are those gray areas the metal (expose because the paint is pulled up) or are they the ground I am seeing through the holes? Whatever they are, I would take care of them. If it's just the paint you are lulling up, simple. If it's the holes, I would cut them off and patch them somehow.
Good luck.
Fat butt 911, 1987
Old 02-09-2008, 03:23 AM
Rust bucket. Part it out!
Old 02-09-2008, 06:23 AM
