KevinG's Avatar
Crank pulley seal/int. shaft cover leak
After over a year, I finally got the rebuilt motor in and running only to find a fairly significant leak behind the engine mount hardware. It appears to be either the pulley seal or the intermediate shaft cover, but I am more inclined to think it is the pulley seal.
Has anyone fixed a leak in this area by putting a jack under the motor and removing the engine mount hardware? I really don't want to pull the motor again if I don't have to.
Thanks!
Kevin
1972 T Targa
Old 02-12-2008, 01:21 PM
KTL KTL is online now
Schleprock
KTL's Avatar
No reason to pull the engine again. Your idea of putting a support (i'd put a padded jack stand instead of a floor jack) under the engine and removing the rear support console is exactly the way a shop would do it- the fast way.
Keep in mind that the leak may not necessarily be your crankshaft end seal or intermediate shaft cover. It could also be the #8 nose bearing shell/o-ring leaking. I've replaced both my crank seal and intermediate shaft cover o-ring and I still get dampness behind the crank pulley.
Kevin L
'86 Carrera "Larry"
Old 02-12-2008, 01:34 PM
onboost's Avatar
Yeah, doing that fix right now on my Turbo...
KTL is spot on with his assessment!
RGruppe #180
Old 02-12-2008, 02:06 PM
