DByers's Avatar
Tire Experts - is this still good?
So I purchased some rims fitted with slightly used Kuhmo V700's on them and have put another 3 track days on the set. After my last event while putting my street setup on for the drive home I noticed a slight slice/gash. Its not deep, maybe 1/32" at best but I was hoping to run these at least one more event. All the other tires have even wear and are probably near perfect as far as grip goes. I was going to run these since I don't drive to the track on them (I pile them inside my 71) but a blow out @ track speeds does not sound like fun to me. This is a rear tire also.
Pics
If you look at the slice it is almost a perfect 90deg to tire rotation. Could it be some sort of de-lamination, or rubber pulling apart?
Any and all thoughts are appreciated.
TIA
Dan Byers
Old 02-10-2008, 01:51 PM
slodave's Avatar
Dan, did you post about this before? I remember a thread similar to this and had the same issue. I think the overwhelming response, was to ditch the tire.
Dave
Old 02-10-2008, 02:05 PM
jonbot's Avatar
I don't know anything about using tires for competition, but I did find this page over at tirerack, might be useful.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=161
- Everything's easier once you get started. -
'95 993 C2
'73 911 Targa
'88 BMW M3
'84 Mercedes 190e 2.3 16v
Old 02-10-2008, 02:09 PM
i wouldn't run it. local PCA rules also state no cuts or cracks in the tires. wouldn't get through my track inspection.
206 637 4071
Old 02-10-2008, 02:10 PM
Michael Delaney wanna-be
Netspeed's Avatar
Weird....it's so even across the tire that I doubt it was cut. Did the tire sit while hot on a loading ramp of a trailer? It might have put a crease in it. It would have a pretty good bulge if it was structural. I'll see if I can get my friend to take a look at the pic.....just for curiosity's sake.
I agree with John...I wouldn't run it on the track. Save it for an autocross....
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 02-10-2008, 02:25 PM
DByers's Avatar
Thanks guys for affirming my gut feeling. Street tires for the next few events for me.
Dave, this is the first I have posted on this. Noticed it after a session at streets.
jonbot, That page was very useful, thanks!
Netspeed, No trailering for my car. I haul the tires in the passenger seat and trunk then change them at the track. I have switched the rears and fronts from drivers side to passenger side after the first 2 events. I guess I should not complain as the rims and tires were cheap enough when I bought them that getting 1 track day was more then my $ worth.
JW, As usual your advice is sound and taken.
Thanks all. I will pull the tires off and sell the rims.
Dan Byers
Old 02-10-2008, 03:27 PM
That appears to be a belt joint separation.....where the two ends of a layer of rubber meet.
I'd run it for AX, but not on the track.
JPIII
Early Boxster
Old 02-10-2008, 03:49 PM
Netspeed's Avatar
Here's what my buddy said. He's got over 20 years of tire-industry knowledge:
"Tire is fine. Its just in the tread so no structural integrity is lost. If the cut extended into the belt package it would be a problem. The rules are there for safety issues but this is just in the soft(usable) part of the tire. I think with another go 'round the "cut" will disappear. "
88 Carrera Cab
Old 02-10-2008, 04:05 PM
450knotOffice's Avatar
Personally, Dan, I wouldn't risk it. If I were you, I'd use them for Autocross, as J P Stein mentioned, but I wouldn't want to be loaded up at about 120ish through turn 8 at Big Willow and have it go. That would be really ugly, at best.
Old 02-10-2008, 05:25 PM
Make Bruins Great Again
Por_sha911's Avatar
I know nothing about tire engineering but I am sure that if you run that tire at the track you will be wondering if you made the right decision and will have a harder time keeping your mind focused. For that reason, I say don't do it.
Joe
Old 02-10-2008, 05:32 PM
3.2 CAB's Avatar
DO NOT RUN THAT TIRE!!! That tire is loosing the tire tread belt. It could peel-off in one long piece the next time it gets hot. Then you can have a 20 pound "band-aid" missile flying around below your oil lines, oil tank, etc., and then possibly removing said items, that it might hit. But, it is your car, but the other people that may be in the range of this flying decapitation device, would probably appreciate it if you stayed at home that day, OR not use the tire. If one of them is doing this, I would advise to really EXAMINE the other tires, to check for this SAFETY DEFECT!!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-11-2008, 06:20 AM
the thread was mine... I called Kuhmo and they said it was fine to run on the track. Your "cracks" look a bit bigger than what I had.. I would call them and if necessary send them the picture. I ran a track day with two drivers when my tires had the smaller cracks and they don't look any worse.
Old 02-11-2008, 07:54 AM
I believe Kumho had a recall due to this. But it was 3 or 4 years ago if memory serves.
A couple of years ago, a friend had some V700's do this while on the tires for the first time. I believe Kumho replaced them under warranty.
I wouldn't run them...
Old 02-11-2008, 10:41 AM
KTL KTL is offline
Schleprock
KTL's Avatar
More information about tread splices
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=160&currentpage=161
Also, the Kumho recall was the Ecsta V700, not the Victoracer V700. Different tire that what is shown on this topic.
Kevin L
'86 Carrera "Larry"
Old 02-11-2008, 05:38 PM
the small slices I have are on Victoracers... Kevin, thanks for the link... good info.
I'll watch very close...at this point .. I'm due for a new set anyway... I've lost track of how many track days are on this set.. I've flipped them on the rims one time.. that could have caused the small cracks to come out sooner...
Old 02-11-2008, 05:47 PM
slodave's Avatar
I knew I saw a previous thread on this. I was thinking about going into the fortune telling business for a moment!
Old 02-11-2008, 06:01 PM
Thanks for the correction. I guess my memory doesn't serve.
Old 02-12-2008, 01:25 AM
How confident on the track are you going to be with questionable tires?
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 02-12-2008, 04:47 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Looks like Kevin nailed it with the Tire Rack link posted - follow the insructions and you shold be fine.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-12-2008, 06:37 AM
DByers's Avatar
Thanks again for all the info. I will probably use them for an A/X this April and see if the gap closes. Wont run these at a track event, just does not feel right.
Ingo - Call me when you can this AM.
Dan Byers
Old 02-12-2008, 06:42 AM
