Rich Hilgersom
Guest
Posts: n/a
Post Where are your nipples?
Not those!.. your brake bleeders. I have M calipers in the front and SC type calipers in the rear. Since these are going on a 914 I dont know which side is which.
I assume the single bleeders go on the top but I have seen some pics where they are on the bottom.
On a side note. My front M calipers have very small bleeders. They do not match the speed bleeder type Pelican sent me. Is there a variation on these calipers? I rebuilt them with M caliper kits,they use M caliper pads and have the line input on the side so I am fairly sure these are M calipers but without part numbers I cant be certain. Any clues?
Thanks,
Rich
Old 04-13-2001, 11:46 AM
efeinsmith
Guest
Posts: n/a
Post
On single bleeder calipers, the nipple should face up. There were some dual bleed calipers made that were able to be used on either side which may explain a downward facing nipple.
Old 04-13-2001, 12:12 PM
