nkotselas's Avatar
Basic exhaust Questions sc/3.2
I have a ROW 3.2 attatched to my old ROW 1978 sc exhaust, I'm curious
1. where the best performance gains can be found on this.
2.Sc exhaust system is worse than the carrera correct? BY how much?
3.And someone told me he can get my car up 30-40 horsepower for 700 dollars only with exhaust, is this possibly?? Remember I live in California so he would have to pass smog as well.
I searched and was still confused
Old 06-03-2011, 09:51 AM
RETIRED
Joe Bob's Avatar
30-40 hp is optimistic....more like 15-20, less on a 3.2 as the exhaust has less restrictions.
Going with early HEs or SSIs allows the engine to breathe better. Problem is that in CA you have smog issues for the modifications. The mod does not allow for a cat.
2012 ML350 3.0 Turbo Diesel
Old 06-03-2011, 09:56 AM
Mike Holbrook
So what we have here is a 3.2 in a 1978 911 SC. In CA you will have to have a cat and air pump to pass SMOG. The cat-back exhaust upgrade to M&K would be my recommendation. It will probably up your HP only minimally, maybe 10hp. To get any more, you have to lose the cat. I doubt you would get through SMOG without the CAT and air pump with all the exhaust plumbing in place. You could put a pipe on it before the exhaust and reinstall the cat every year or two when you have to smog it.
Welcome to the Republic of Kalifornia....move to Idaho, we have no such nonsense for 1979 and older.....
Mike Holbrook
Meridian, ID
1979 911SC Targa
Old 06-03-2011, 10:14 AM
nkotselas's Avatar
Yeah our cutoff date is 1974, i don't have a cat and my mechanic doesn't either with the same setup and he passes smog. He said if needed he could temporarily put one on so im not worried about that. What about heat exchangers, premufflers and stuff like that?
Old 06-03-2011, 10:19 AM
Flat Six
Flat Six's Avatar
Actually, it's MY 1975 or older that are smog exempt. Also depends on which county it's registered in. See here: Smog Information
Your wrench may live in one of the few SD county ZIP codes that doesn't require smog check; otherwise you're getting bad advice. Regardless of how clean your HC, CO, and NO levels are, if you're required to have a smog cert you're going to fail the visual 'under hood' inspection if the inspecting technician finds any of the emissions equipment (including cat, O2 sensor, air pump, EGR, thermal reactors, fuel injection components, or warning lights) required on whatever MY your vehicle is, is missing or inoperative.
I had a 944S2 pass the sniffer but fail the visual because the CEL in the dash had a burned out bulb.
Search 'smog check' in this forum; you'll find plenty of more accurate -- and useful -- info than you seem to be getting from your wrench.
Another 3.2 Fails CA Emissions
Trying to pass CA smog check and stumped!
CAL - 76 911S failed smog
Moving a Euro SC to California
CA Emissions
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-03-2011, 12:04 PM
nkotselas's Avatar
Youre right, when i first looked up the law i think it said cars that began production in 74 so that also included 75 models (dont quote me on that)
Im not exactly sure what he has in his car but i know its an sc and has a 3.2, they might both even be US spec. So I might not be in the same boat as him but he said I should be ok and if not we will do the tweaks required
Old 06-03-2011, 12:57 PM
Green Skull 006
Jim Garfield's Avatar
With the 3.2, there is a lot of low hanging fruit that can increase HP for not much money - if you can get rid of the cat. B&B headers, tweaking the DME switch, and a Steve Wong chip will really make these engines come alive.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 06-03-2011, 01:19 PM
