Brad w's Avatar
chain tensioner upgrade
Getting ready for a chain tensioner upgrade on my 80SC. I just replaced the chain ramps and noticed that on the left side the lower chain is loose. I can easily lift it off the ramp a 1/2 inch with no effort. What are your thoughts?
Do I need to replace the chain or will the new tensioner fix this.
Also the top of the chain is very tight as well as the right side.
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 02-13-2008, 06:46 PM
Friend of Warren
A picture showing the top of the tensioner would be helpful. Would like to see if it is collapsed.
Kurt V
Old 02-13-2008, 07:17 PM
I would like to know if it is collapsed also.
Old 02-13-2008, 07:42 PM
Brad w's Avatar
I'll post them when I get home from work
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 02-14-2008, 03:46 AM
Capitalist and Patriot
911Freak's Avatar
Did mine today...looked same way; reason? Tensioner collapsed.. same side too!? consider yourself lucky like I do..could have been much worse
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 02-14-2008, 05:37 PM
Won Won is offline
Won's Avatar
Is your engine at TDC? I forgot that little detail when I opened mine up last weekend and the left side cam wanted to rotate CCW (depends on crank position of course) hence no tension on the bottom portion of the chain. I had to put a wrench on the cam nut and turn it CW to give the chain some slack while I installed the tensioner.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 02-14-2008, 06:24 PM
