viper4490's Avatar
Help.. really loud buzzer!
I have a 76 911. I was driving it yesterday and all of a sudden this really loud buzzer goes on. At first I thought it was the horn and that somehow the wires were touching but it wasnt the horn.. They sounded different. But the buzzer was on for awhile like 3-4 min...Anybody know what it is?
Old 02-15-2008, 07:36 AM
From front of car? Reference to horn sounds like it.
First thought is fuel pump is heading South.
Also I've heard similar when my front fresh air ventilation fan (w/ crummy bearings) behind dash, came on by itself when I hit a bump.
Only other things up there are, if you have A/C, the evaporator blower in the smuggler's box or the condenser fan by the battery.
Old 02-15-2008, 08:37 AM
if your car has a factory alarm, it could be the alarm horn going off
Old 02-15-2008, 12:12 PM
MBAtarga's Avatar
Could it be the seat belt warning relay?
Mark
'83 SC Targa - since 5/5/2001
Old 02-15-2008, 12:31 PM
Anachronistic Anomaly
lfot's Avatar
That's what I was thinking. Need a little more info though. Pull the Temp/Druck or RPM gauge out. If the sound gets louder, it's probably the belt warning relay. Carefully feel around in there for a boxy relay that might be shaking/buzzing. If it is, pull it out. You might have a bad relay or a bad connection making it go off.
IG@ the_derek_whitacre
Old 02-15-2008, 12:46 PM
Registered Abuser
MT930's Avatar
Check the front air con condenser blower motor, when it starts going out (bearings) it sounds just like a buzzer very loud.Only happens when the air con is on. It had me looking all over. Easy fix
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 02-15-2008, 01:05 PM
