			 Senior Member
				'79 RoW Questions
			I've got a '79 Row car now.  I'm wondering about differences.  My last car was '83 USA.
				I know that early USA SC's had 8.6:1 CR pistons and wider intake ports and runners. Later USA SC engines had narrower ports and runner, and 9.3:1 CR pistons. Later RoW SC engines had 9.8:1 CR pistons, but I do not know what CR pistons were used in earlier RoW SC engines. What kind of pistons do I have? What kind of intake ports and intake runners do I have (wider, I assume). What kind of spark plugs are required in this engine? Would a tachometer from an '83 USA car work in a '79 RoW? Are the speedometers interchangeable?
	Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco"  |
			MY79 RoW
			930/03 8.6 cr 180hp@5500 175ft-lbs@4200 ign cutoff 6800+/- 200 valves 49/41.5 ports 39/35 1.81 fan ratio, 126mm same p/c as US 915/61 trans
	Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes |  |
			I'm pleased you have a new car Super.  Lets see some pics
			Super, I've just looked at my '79 ROW manual and Das buch says sparkplugs are Bosch W225 T 30 (W 5 D) or Beru 225/14/3 A (14-5 D) and a gap 0f 0.031" or .8mm.
			 Senior Member
			Thanks.  I'll be taking some pics this weekend.
