khamul02's Avatar
may be the stupidest question ever
Can I start my engine with my car on jack stands?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-09-2008, 07:09 PM
yes but judging by the stupididy of your question id say you probrobly shouldnt because you probrobly have it supported improperly
Old 02-09-2008, 07:19 PM
Regis turd ab user
stupididy id probrobly shouldnt probrobly
Isn't that ironic!
Old 02-09-2008, 07:30 PM
khamul02's Avatar
It's on 4 stands and you can shake it pretty hard with very little movement. Common Sense would tell me it's OK. But I'm pretty stupidididid
Tom Hutchinson
Old 02-09-2008, 07:41 PM
Regis turd ab user
If it's sitting square and level and doesn't wobble you'll be fine.
Keep the tires and wheels on it, or under it.
Old 02-09-2008, 07:49 PM
theclaw's Avatar
I've started my car on the mid-rise lift 4ft in the air. As long as its properly supported you are ok.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 02-09-2008, 08:19 PM
72 four door's Avatar
No stupid questions here. Just dont rev the crap out of it. If its on a lift no problem but on stands id be careful.
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 02-09-2008, 08:52 PM
barney911rs's Avatar
When my race car was running, I did it all the time. +1 on making sure it's securely supported.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 02-09-2008, 11:28 PM
eauboy's Avatar
Don't forget to properly ventilate the area you are working in as well...
'85 Carrera Iris Blue Metallic Coupe
Old 02-10-2008, 04:53 AM
I hope you aren't going to crawl under it. It's not worth the risk.
1990 Wanderlodge PT-40
75 911S Silver Anniversary
1952 MGTD
1983 Mercedes 300 TD
1969 Lincoln
Old 02-10-2008, 06:03 AM
Komenda Fan's Avatar
I hope so, I did it yesterday. Just make sure the car is securely supported. I always shove the car side to side and front to back a bit before I get started working on it. A properly supported car should have no movement.
As for it being a stupid question - it's not. Firstly, safety questions are never stupid, and secondly, if you are asking, I bet there are dozens of others with the same questions. We all come here to learn things we didn't know, and no one is born with this knowledge.
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 02-10-2008, 08:14 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Why does this scene suggest to me the old "falling off the stands and running through the back of the garage" scene from Keystone Cops movies?
If you exercise extreme caution and brace the car properly, I see few problems.
But if you are the only one there....no way...do not try this alone.
Have someone else there and standing to the side or out of any possible harm's way to observe, just for the sake of safety.
Bob
Bob Hutson
Old 02-10-2008, 08:56 AM
khamul02's Avatar
Nice idea about the the jack under the engine. I did that as well as put the wheels back on. Everything went great the car didn't budge.
I just did a valve adjustment and am in the process of stripping several parts to have the front end and rear valance painted. So I really just wanted to move a little oil around since the engine was drained and the car will probably be on stands for another 2 weeks. Things are pretty humid down here right now & I noticed a little surface rust start to build after the valve covers where off for only a few days. I brushed some oil on the adjustment nuts (that is what started rusting) and hopefully running the engine for a good while gets everything lubed up.
Thanks for all of the advice.
Tom Hutchinson
Old 02-10-2008, 12:25 PM
What are the proper undercarriage contact points when using jack stands on a 911, a 993 in particular?
Old 02-16-2008, 05:14 PM
UnRegistered User
billybek's Avatar
Hey Larrya,
Welcome to the forum!
If you use the search this forum feature and type in lifting and or jack stands there will be tons of information on lifting the car and properly supporting it.
This is a great source of information and a lot of it is in the historic threads.
Why don't you formally introduce yourself on a new thread and post some pictures of your car??
Bill K.
Old 02-16-2008, 05:40 PM
khamul02's Avatar
Larrya
That is the custom
Tom Hutchinson
Old 02-16-2008, 05:45 PM
If you dont worry about your safety you wont be safe.
Old 02-16-2008, 06:25 PM
