cstreit
Guest
Posts: n/a
Post Help for bouncing tach
My 70S tach will bounce quite a bit after my shift. When I am running steady it works fine, but then when I sift gears it drops down, bounces way up a few times.
Is there some sort of damper? Bad ground?
Thanks,
Chris'
Old 04-15-2001, 07:23 AM
Superman
Guest
Posts: n/a
Post
No. My tach does two kinds of bounding. First, it bounces like you say. Also, when holding a steady speed, it sometimes wiggles maybe 50-100 rpm. Just occasionally.
Other than that, my gauges are very steady.
'83 SC
Old 04-15-2001, 07:59 AM
terrymo
Guest
Posts: n/a
Post
One possibility on the early cars is that the tach needle bouncing is a symptom of the points going out.
Old 04-15-2001, 08:10 AM
john walker's workshop
Guest
Posts: n/a
Post
there is also an internal damper that requires a trip to the speedo shop to repair.
Old 04-15-2001, 08:43 AM
cstreit
Guest
Posts: n/a
Post
What is this damper of which you speak? I don't have points... Have an 80 3.0L with MSD ignition...
Old 04-17-2001, 08:43 PM
Guest
Posts: n/a
Post
i'm not a tach repairman, so i send them out to north hollywood speedometer to fix them. i don't know what the damper is but they fix it. the ignition points, when old make it jerky, not smooth floating.
[This message has been edited by john walker's workshop (edited 04-18-2001).]
Old 04-18-2001, 08:21 AM
pwd72s
Guest
Posts: n/a
Thumbs up
Just a blatent plug for North Hollywood...I've sent instruments to them a couple of times, and everything worked out for me exactly as promised.
Old 04-18-2001, 02:37 PM
Jim T
Guest
Posts: n/a
Post
Sounds similar to the problem a lot of 914 tachs have.
I agree it is the internal dampner. There may have been some posts on the dampner on the 914 list, I don't recall the details, though.
Old 04-18-2001, 11:33 PM
