cattman's Avatar
Are these Fuchs polished, anodized, what?
Are these Fuchs wheels polished or anodized? I believe they were re-finshed by Weidman at some point by a PO.
I want to get some water spots off of them, but I am not sure if I should use Vaseline, Mother's, NeverDull or what? Any help is appreciated.
Thanks!
CATTMAN
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Old 02-04-2011, 12:48 PM
Band.
Those are definitely polished. Make sure there's no clear spayed on it and then use whatever you want!
Old 02-04-2011, 12:51 PM
Checked out
McLovin's Avatar
Not anodized, they look polished or (hopefully not) chromed. My guess is polished. Take a little metal polish on a white rag and lightly rub a spot. If they are polished, you'll see black on the rag very quickly. If they are chromed, the rag will stay clean no matter how much you polish.
Old 02-04-2011, 12:53 PM
cattman's Avatar
How do I determine if they are clear-coated or just raw polished?
CATTMAN
The rims are polished. I would suggest that you use P21S to clean them. I think it's available from our host.
Old 02-04-2011, 12:56 PM
RETIRED
Joe Bob's Avatar
CATTMAN
Try uses a light polishing compound on them. It may cut thru any clear coat but I think you want to get them brighter, right? They look to be w/o any clear on them.
Vaseline works on anodized which is a duller than clear coat protectant.
2012 ML350 3.0 Turbo Diesel
Old 02-04-2011, 01:03 PM
