-   -   Un-installing a Robotek shift kit (http://forums.pelicanparts.com/porsche-911-technical-forum/394668-un-installing-robotek-shift-kit.html)
tmctguer 02-24-2008 02:48 PM
If I were to un-install a Robotek shift kit, what would I need to do to restore my shifter to it's pre-existing condition? for example,
1). I had a factory short shift kit, so I had cut out the small notch in the gear shift housing to accommodate the longer pin of the Robotek. do I need a new shift housing?
2). I replaced the pin from the short shift kit with the longer pin in the Robotek kit. do i need another short pin?
i put in the Robotek about 4 years ago. I took the shifter out today and was looking at it and i wanted to ask before I started buying parts or taking them out.
thanks.
930LDR 02-24-2008 03:06 PM
You may likely be better off just trading complete shifter units with someone who might be in the market for what you already have.
tmctguer 02-24-2008 04:34 PM
that is a great suggestion...........thanks !
