jpaugh's Avatar
CV-joint rebuilding
I'm looking to rebuild my CV-joints and I pretty much know the ball-bearings will need replacing. Anyone know where to source them? What's the consensus on rebuilding? If the balls need replacing, just punt and buy a new CV's? Hoping to salvage mine, but I let them go way too far before a rebuild.
Thanks in advance.
- Jim
Old 02-26-2008, 05:26 PM
AutoBahned
RWebb's Avatar
it's a time vs. cost issue -- some think it fun to rebuild them
did you play with mud a lot as a kid? if so, you may love doing this.
it is certainly instructive to do it....
there is a thread with images from a VW manual that will be very helpful to you if you can find it.
Old 02-26-2008, 05:31 PM
I've never seen CV parts [ball bearings, inner piece andouter "cage?" ] for sale as individual parts..
When my CV's went > there were definite groves in the inner piece > ergo replace the entire CV joint.
Personally > I would not replace suspect individual pieces of a CV joint > but replace the entire CV as a single unit. >>> some argue that it's best to just replace the entire axle/CV assembly
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 02-26-2008, 05:40 PM
911quest's Avatar
You might be able to find a local re builder that will regrind and fit oversize bearings...most larger city's have someone that does it....If you track the car or do any hard driving I would just get new axle assemblies
Tony Proasi
1969S
1957 VW Pickup
Old 02-26-2008, 05:58 PM
jpaugh's Avatar
Thanks for the useful info. This is kind of what I expected. This is for a track car, so I'm going to go ahead and order up some replacement axles. I'll just be more diligent about pulling, cleaning and repacking them on a regular basis.
Thanks!
Old 02-26-2008, 06:15 PM
Tsunamiboy's Avatar
This is what you need
http://www.*****************.com/product_p/pp911.332.030.01.htm
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 02-26-2008, 06:18 PM
jpaugh's Avatar
Originally Posted by Tsunamiboy View Post
Hm, problem is my car is a '74 with the four bolt cv-joints (two pins). Doesn't seem to be rebuild kits for those CV's. In fact, I'm told that the CV's are no longer available and you I have to go with a 930 CV's and drill two of the holes for the pins?
Old 02-26-2008, 06:23 PM
Loose nut bhind the wheel
Tsunamiboy,
That is just disrespectful. You should at least post a link to the Pelican Parts site and not another supplier.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 02-26-2008, 08:50 PM
356RS's Avatar
Jim, I'm using 930 CV's on a 74 and the pin fits the hole fine without drilling.
Mark Jung
Bend, OR
MFI Werks.com
Old 02-27-2008, 07:43 AM
Mahler9th's Avatar
Jim:
Give me a call. I have all of the answers for you. Including part numbers, best prices, and best approaches. And advice from Mat.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-27-2008, 08:21 AM
