Input on pad retainer button head screws
Could use a little help on removing 993 brake pad retainer button head screws. Using a
M4 allen wrench I got 2 out the other 2 will not budge. Any suggestions from all the Pros !!! Cole |
I know you know what you're talking about but I'm going to have to guess: :D
I'm guessing you have a 930. I'm guessing you mean brake pads? I'm guessing you mean the little screws that the hold the spring plates that the brake pads ride/slide on? If so, you might try heat on them in case they are Loctited. -Chris |
Chris,
Thanks for the reply any help at this point is appreciated. |
| All times are GMT -8. The time now is 08:44 PM. |
