Input on pad retainer button head screws
Could use a little help on removing 993 brake pad retainer button head screws. Using a
M4 allen wrench I got 2 out the other 2 will not budge. Any suggestions from all the Pros !!! Cole Last edited by cole930; 02-27-2008 at 07:11 AM.. |
Irrationally exuberant
I know you know what you're talking about but I'm going to have to guess:
![]() I'm guessing you have a 930. I'm guessing you mean brake pads? I'm guessing you mean the little screws that the hold the spring plates that the brake pads ride/slide on? If so, you might try heat on them in case they are Loctited. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris,
Thanks for the reply any help at this point is appreciated. |
