Vincent 911's Avatar
SC rear wheel bearing look like turbo wheel bearing
Hello,
I drove my 911 for the first time last Sunday! Actually I bought the car with broken head studs... It is a 78 SC ROW. I have rebuilt the top end of the engine, brakes, suspensions, interior this winter + some upgrades: Carerra tensioner, 964 cams, SSIs, Dansk sport, Biltein HDs, turbo tie rods...
So I drove the car on Sunday: slowly in my residence. It appeared that I have a knock at the rear right wheel. It was quite loud. It seems to be a broken wheel bearing. I have a free play of maybe 3mm! I can wiggle the hub.
I have disassemble the rear right wheel bearings yesterday evening and find out that my bearings are not the SC bearing I was expecting to see. I mean the bearing is not not the angular contact bearing which is hard to remove. Actually I have 2 ball bearings whick look like the turbo bearings but not exactly.
I will post a picture soon.
Have you ever seen this kind of rear wheel bearing on an SC? Remeber: it is an 78 SC ROW.
What would be the part number replacement?
Not these bearings:
Thank you,
Vincent
Red 911 SC euro 78 - 964 cams, Carrera tensionners, new steel head studs, SSI & dansk 2 in 1
Old 02-26-2008, 07:53 AM
sjf911's Avatar
The upper bearing is the correct single rear wheel bearing for the SC. The outer race comes off on the hub shaft destroying the bearing and exposing the outer ball cage when you disassemble it so that may be what you are seeing. The bearing has two separate races and ball cages in one shell (inner and outer).
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-26-2008, 10:10 AM
Thank you. You were 100% right. I have removed the outer race of the bearing thanks to a home made tool and heat. It appears it is a standard SC rear wheel bearing like the top picture.
Now I am waiting for the new bearing.
Vincent
Old 02-27-2008, 05:47 AM
UnRegistered User
billybek's Avatar
Might as well do the other side as well.
While something could have happened to the defective side, quite likely it is a duty cycle thing.
Just a suggestion.
Any pics of your adventures in upgrades over the winter???
Bill K.
Old 02-27-2008, 05:55 AM
Just a suggestion.
I have ordered 2 wheel bearings. I will change both sides.
Old 02-27-2008, 06:27 AM
UnRegistered User
billybek's Avatar
That looks great! Cold, but great.
Get some insulation in those walls and some heat going on in there!!
Bill K.
Old 02-28-2008, 05:08 PM
