Scott R's Avatar
I can't get comfortable in my SC
I had the seats re-done, they are non sport, but damn it I'm 6' 1" and I look like a long necked moron driving my SC. And suggestions on alternative seating for tall guys?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-29-2008, 06:51 PM
Anachronistic Anomaly
lfot's Avatar
I'm 6'2". Recaro SRD's (Now called Recaro Speed's). They use the stock rails and sliders, but will drop you down about 3".
IG@ the_derek_whitacre
Old 02-29-2008, 06:55 PM
Scott R's Avatar
Thanks! Will look into getting a set.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-29-2008, 07:04 PM
Registered Usurper
DARISC's Avatar
Hmm...I'm 6" 1 1/2", long waisted and I fit fin in my stock seats.
'82 SC RoW coupe
Old 02-29-2008, 07:08 PM
lfot's Avatar
I did too, but barely. If he just had the seats redone though, the padding will probably be stiffer and fuller than a worn in seat.
Old 02-29-2008, 07:17 PM
4flyboy's Avatar
I'm 6'4" and own an '85 coupe. I had no idea that '85 seats were mounted higher than other years. My head is up to the ceiling. I'm afraid of lowering the seat rails and welding on that tunnel with the fuel lines. Nice to know that SRD's sit a full 3" lower. Do you think that this would hold true of some vintage Recaro LS's with a Recaro mounting rails. I'm considering a relatively expensive set of those but it would help the decision if I knew it would solve this problem. Thanks and sorry for the hijack.
Scott
P.S. If it makes you feel any better I look like Herman Munster with the sunroof open.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 02-29-2008, 09:47 PM
I'm with Bill
Rick V's Avatar
I'm 6-4, and long in the torso. With the stock seats I would brush the headliner, even the way I keep my seat. I installed a set of Currillo sports and got just enough head room to not get "helmet hair"
Old 03-01-2008, 04:33 AM
I'm 6'-2", no sunroof, stock seats, lot's of clearance in my 80SC. Do you have a sunroof on yours? I bet you lose 2" with a sunroof?
John Adams
1980 ROW 911SC
Old 03-01-2008, 06:31 AM
RETIRED
Joe Bob's Avatar
I have the SRDs....I'm 5 10"......I look like a midget and have TONS of head room....but hey are good seats....
2012 ML350 3.0 Turbo Diesel
Old 03-01-2008, 07:23 AM
Cut the factory seat rails out and weld in a structure between the sill and the tunnel. Many, many of us have done this with our race cars. It's a much safer structure and you'll get about 3 more inches. I'm short and when I race, I have to take off my windshield wipers or I can't see over them
You can also make the new structure in such a way that you can move your seats back farther than stock rails allow. If need be, you can add a spacer to your steering wheel to bring it closer to you.
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 03-01-2008, 07:27 AM
Scott R's Avatar
No, its a Targa, and I have to recline the seats to a almost "ghetto" position to get some sort of comfort out of them.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-01-2008, 07:50 AM
It's actually worse if you're short. The pedal distance is long. Much better in a Boxster.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 03-01-2008, 07:52 AM
That's strange. Targas have more headroom than a coupe dont they?
Old 03-01-2008, 08:53 AM
Designer King
Paulporsche's Avatar
Try being 5' 4" (5' 7 counting hair!) I can barely reach the pedals.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-01-2008, 09:14 AM
Aircooled Breakfast
Any experiences using these? I would be interested to know how they compare with the stock "tombstone" style seats for seat height/headroom. Alternately, anyone know what would be involved in installing '72 vintage sport seats in a later car?
John
(another tall guy tired of reclining)
Old 03-01-2008, 09:41 AM
6'2" - Targa is a good overall fit.
1989 Carrera Coupe (Black / Linen)
1981 911SC Targa (Black / Chocolate)
Old 03-01-2008, 09:45 AM
Less brakes, more gas!
euro911sc's Avatar
Unfortunately, the tallest part of the 911 is at the front windshield. so if you are tall, the closer you sit to the steering wheel the more height you get out of the roof line. You will notice on the later cars that they fixed this issue.
I'm 6' 1". I have Sparco Pro 2000 fixed back race buckets in the car. I'm fine with no helmet, but I tend to sit closer to the front than most so I can squeeze out the last bit of head room in my sunroof coupe. at the track, I have to remove the seat cushion to get clearance for the helmet.
You can fit. You just have to change your seating position slightly.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-01-2008, 09:46 AM
peritus's Avatar
I'm 6", have Sparcos, and can barely see over the dash.
James
91 Black on Balck 964 C4 (DD)
82 Metallic Red SC 3.6 Varioram (sold)
Old 03-01-2008, 10:00 AM
joe payne's Avatar
As you age you will get shorter and the seats will be broken in, so you should fit perfectly in 10-15 years! Damn, I'm 5'8" so does that mean my car
fits me perfectly?
jtp911
Old 03-01-2008, 10:41 AM
