I can't get comfortable in my SC
I had the seats re-done, they are non sport, but damn it I'm 6' 1" and I look like a long necked moron driving my SC. And suggestions on alternative seating for tall guys?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Anachronistic Anomaly
I'm 6'2". Recaro SRD's (Now called Recaro Speed's). They use the stock rails and sliders, but will drop you down about 3".
IG@ the_derek_whitacre |
Thanks! Will look into getting a set.
Registered Usurper
Hmm...I'm 6" 1 1/2", long waisted and I fit fin in my stock seats.
'82 SC RoW coupe |
I did too, but barely. If he just had the seats redone though, the padding will probably be stiffer and fuller than a worn in seat.
I'm 6'4" and own an '85 coupe. I had no idea that '85 seats were mounted higher than other years. My head is up to the ceiling. I'm afraid of lowering the seat rails and welding on that tunnel with the fuel lines. Nice to know that SRD's sit a full 3" lower. Do you think that this would hold true of some vintage Recaro LS's with a Recaro mounting rails. I'm considering a relatively expensive set of those but it would help the decision if I knew it would solve this problem. Thanks and sorry for the hijack.
Scott P.S. If it makes you feel any better I look like Herman Munster with the sunroof open.
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe Last edited by 4flyboy; 02-29-2008 at 09:51 PM.. |
I'm with Bill
I'm 6-4, and long in the torso. With the stock seats I would brush the headliner, even the way I keep my seat. I installed a set of Currillo sports and got just enough head room to not get "helmet hair"
Electrical problems on a pick-up will do that to a guy- 1990C4S |
I'm 6'-2", no sunroof, stock seats, lot's of clearance in my 80SC. Do you have a sunroof on yours? I bet you lose 2" with a sunroof?
John Adams 1980 ROW 911SC |
RETIRED
I have the SRDs....I'm 5 10"......I look like a midget and have TONS of head room....but hey are good seats....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Cut the factory seat rails out and weld in a structure between the sill and the tunnel. Many, many of us have done this with our race cars. It's a much safer structure and you'll get about 3 more inches. I'm short and when I race, I have to take off my windshield wipers or I can't see over them
![]() You can also make the new structure in such a way that you can move your seats back farther than stock rails allow. If need be, you can add a spacer to your steering wheel to bring it closer to you.
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
No, its a Targa, and I have to recline the seats to a almost "ghetto" position to get some sort of comfort out of them.
It's actually worse if you're short. The pedal distance is long. Much better in a Boxster.
'03 Boxster ***** '82 911SC **** '98 BMW Z3 ** '87 300Z *** '80 BMW 320i **** |
Designer King
Try being 5' 4" (5' 7 counting hair!) I can barely reach the pedals.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Aircooled Breakfast
Any experiences using these? I would be interested to know how they compare with the stock "tombstone" style seats for seat height/headroom. Alternately, anyone know what would be involved in installing '72 vintage sport seats in a later car?
John (another tall guy tired of reclining) |
6'2" - Targa is a good overall fit.
______________________________ 1989 Carrera Coupe (Black / Linen) 1981 911SC Targa (Black / Chocolate) |
Less brakes, more gas!
Unfortunately, the tallest part of the 911 is at the front windshield. so if you are tall, the closer you sit to the steering wheel the more height you get out of the roof line. You will notice on the later cars that they fixed this issue.
I'm 6' 1". I have Sparco Pro 2000 fixed back race buckets in the car. I'm fine with no helmet, but I tend to sit closer to the front than most so I can squeeze out the last bit of head room in my sunroof coupe. at the track, I have to remove the seat cushion to get clearance for the helmet. You can fit. You just have to change your seating position slightly. Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I'm 6", have Sparcos, and can barely see over the dash.
James 91 Black on Balck 964 C4 (DD) 82 Metallic Red SC 3.6 Varioram (sold) |
As you age you will get shorter and the seats will be broken in, so you should fit perfectly in 10-15 years! Damn, I'm 5'8" so does that mean my car fits me perfectly?
jtp911 |
