Anyone know of a source for rear caliper bolts?
I'm rebuilding my calipers and broke a couple caliper bolts during disassembly. Does anyone know a source for these bolts (see pic)? This is a rear caliper from a 911SC. I didn't see them listed on our host's inventory.
Thanks. Geoff
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process |
A.K.A. GOB Bluth
I don't know if the bolts are the same, but I have an old set of calipers off a 1985 Carrera sitting here. Let me know if they'll work and I'll see of they still have bolts in them. If they will and they do, they're yours...
Paul Misencik Huntersville, NC |
If your still looking try www.pmbperformance.com he rebilds alot of calipers and should have what you need
Tony Proasi 1969S 1957 VW Pickup |
Detached Member
Call Pelican before you assume they don't have them. You should support PP whenever possible, or at least give them the chance.
Hugh |
Those are RIBE bolts, sometimes referred to as polydrive (I think this is what snap-on call them.)
andy |
Wer bremst verliert
You really only need the treadpitch, length and width. Any good fastener shop will match them. Change out to a normal head for servicibility.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I'll try Eric at PMBPerformance, thanks. Geoff
Rick 88 Cab |
AutoBahned
I think the reason those are so peculiar is that most people don't split their calipers.
I have always been afraid to do this because of the difficulty in getting them back together without leaking. I always stick to just chaning the o-rings. |
Mcmaster.com, you need to know the pitch, strength and length
1997 911 Carrera Cabriolet 66 912, 67 912 Outlaw 65 Ac Cobra reproduction 2012 Audi A8L 1999 Ferrari 360 Modena |
I doubt they are any higher than 12.9 which is readily available here.
In fact, if you get stuck for some let me know the thread and length and I will get you some and mail them to you! Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
AutoBahned
it's not me, Jeff
I was just worried that people would go out and get any ol' bolt based on length and pitch - not a good thing if a 12.9 bolt is spec'd for the brakes! |
Geoff,
What did you use to refinish the caliper body? Did you send it off for yellow zinc plating?
I feel the need, the need for speed. |
I would just get the 12.9 ones anyways as they are cheap and easy to get here. Cheers
The bolts I need for the rear caliper I'm building are M7x1.0 Ribe bolts. I checked with master 911 brake rebuilder and all-round great guy, Eric, over at PMBPerformance (check out his great tech article on Porsche caliper rebuilding on his website) and he doesn't know of anyone who stocks them. I did a search of fasteners sites and could not find anyone that stocks an M7x1.0 bolt of any sort, let alone one with a Ribe head. An M7x1.0 is dangerously close to a 1/4-28. I'm going to do a little more searching, but I may just swap all the bolts out with 1/4-28's of appropriate strength. Not a perfect solution, but should be functionally equivalent.
Geoff
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process Last edited by squidmarks; 03-03-2008 at 06:05 PM.. |
I will check here for the 7mm, but if memory serves me correct it is a tough find. Probably thursday before I can get out there.... Can you measure the length, not including the head?
Cheers
Jeff,
They're 65mm long. Geoff
If you go back to the 77 model year the bolts are listed
http://www.pelicanparts.com/PartsLookup/HTML/911T_USA_KATALOG/603-00-Frame4.htm
