Anyone know of a source for rear caliper bolts?
I'm rebuilding my calipers and broke a couple caliper bolts during disassembly. Does anyone know a source for these bolts (see pic)? This is a rear caliper from a 911SC. I didn't see them listed on our host's inventory.
Thanks.
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 03-01-2008, 05:24 PM
A.K.A. GOB Bluth
carolinatrophy's Avatar
I don't know if the bolts are the same, but I have an old set of calipers off a 1985 Carrera sitting here. Let me know if they'll work and I'll see of they still have bolts in them. If they will and they do, they're yours...
Paul Misencik
Huntersville, NC
Old 03-01-2008, 06:17 PM
911quest's Avatar
If your still looking try www.pmbperformance.com he rebilds alot of calipers and should have what you need
Tony Proasi
1969S
1957 VW Pickup
Old 03-01-2008, 06:45 PM
Detached Member
Hugh R's Avatar
Call Pelican before you assume they don't have them. You should support PP whenever possible, or at least give them the chance.
Hugh
Old 03-01-2008, 08:21 PM
Those are RIBE bolts, sometimes referred to as polydrive (I think this is what snap-on call them.)
andy
Old 03-02-2008, 03:22 AM
Wer bremst verliert
JohnJL's Avatar
You really only need the treadpitch, length and width. Any good fastener shop will match them. Change out to a normal head for servicibility.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-02-2008, 03:48 AM
Paul, thanks for the offer, but I think the calipers on an '85 are different than my SC. At least the rebuild kits and pistons are different according to Pelican's catalog.
I'll try Eric at PMBPerformance, thanks.
Geoff
Old 03-02-2008, 05:37 AM
Detailed search for bolts and o-rings
thread
Rick
88 Cab
Old 03-02-2008, 08:58 AM
AutoBahned
RWebb's Avatar
- are you certain they not high-strength bolts??
Old 03-02-2008, 11:25 AM
I think the reason those are so peculiar is that most people don't split their calipers.
I have always been afraid to do this because of the difficulty in getting them back together without leaking. I always stick to just chaning the o-rings.
Old 03-02-2008, 02:15 PM
MarKoBrow's Avatar
Mcmaster.com, you need to know the pitch, strength and length
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 03-02-2008, 03:49 PM
Jeff Alton's Avatar
I doubt they are any higher than 12.9 which is readily available here.
In fact, if you get stuck for some let me know the thread and length and I will get you some and mail them to you!
Cheers
www.turn3autosport.com
Old 03-02-2008, 10:04 PM
AutoBahned
RWebb's Avatar
it's not me, Jeff
I was just worried that people would go out and get any ol' bolt based on length and pitch - not a good thing if a 12.9 bolt is spec'd for the brakes!
Old 03-03-2008, 12:30 PM
blk911's Avatar
Geoff,
What did you use to refinish the caliper body? Did you send it off for yellow zinc plating?
I feel the need, the need for speed.
Old 03-03-2008, 04:21 PM
Originally Posted by blk911 View Post
Geoff,
I media blasted the caliper halves to then painted with caliper paint. I could have plated them, but the power supply I have for my plating bath does not supply high enough current to do large parts like a caliper well. Below is the before/after for the front brakes. I did re-plate the nuts and bolts, tho.
Old 03-03-2008, 04:29 PM
Jeff Alton's Avatar
it's not me, Jeff
I hear you, wasn't trying to poke you.
I would just get the 12.9 ones anyways as they are cheap and easy to get here.
Cheers
Old 03-03-2008, 05:13 PM
The bolts I need for the rear caliper I'm building are M7x1.0 Ribe bolts. I checked with master 911 brake rebuilder and all-round great guy, Eric, over at PMBPerformance (check out his great tech article on Porsche caliper rebuilding on his website) and he doesn't know of anyone who stocks them. I did a search of fasteners sites and could not find anyone that stocks an M7x1.0 bolt of any sort, let alone one with a Ribe head. An M7x1.0 is dangerously close to a 1/4-28. I'm going to do a little more searching, but I may just swap all the bolts out with 1/4-28's of appropriate strength. Not a perfect solution, but should be functionally equivalent.
Geoff
Old 03-03-2008, 06:02 PM
Jeff Alton's Avatar
I will check here for the 7mm, but if memory serves me correct it is a tough find. Probably thursday before I can get out there.... Can you measure the length, not including the head?
Cheers
Old 03-03-2008, 06:39 PM
Jeff,
They're 65mm long.
Geoff
Old 03-03-2008, 06:49 PM
911quest's Avatar
If you go back to the 77 model year the bolts are listed
http://www.pelicanparts.com/PartsLookup/HTML/911T_USA_KATALOG/603-00-Frame4.htm
Tony Proasi
1969S
1957 VW Pickup
Old 03-03-2008, 06:58 PM
