HELP? Fiberglass bumper fitment.
So I got the week off and I am working on my rear bumper replacement. Purchased used from another Pelican. It was a little to narrow so I did relief cuts and got the flares to line up fairly good. The problem is under the tail lights. Now what??
I can not find it binding any where. Is there some thing I can do or should I just live with it. I really want the early style bumper. ![]() ![]() ![]() ![]()
Mike '99 Isuzu VX, 2005 Audi A4 1.8T Quattro '96 BMW 328ic '73 911T Targa SOLD www.flickr.com/photos/fenderbender813 |
Commerical Pilot
PM me at jack@nni.com, I can help you out....Jack
pm sent, Jack
Wow, that bumper is really hosed or your car has been whacked pretty good on a rear corner. I've faced both situations. I hope Jack can help you out because you're basically gonna cut that up into sections and rework it to fit. See the upwards deflection at the center bottom? Not good.
I guess your new name is bumperbender. |
Milt, I was hoping you would chime in. Love how your car turned out.
The upwards deflection at the center bottom I noticed. The paint was yellowed under the bumperets, from a dual exhaust set up. This came from a race or track car. Could it be warped from heat? I found no evidence of any collision repair. BumperBender, LOL!!!!!
This is the previous bumper.
While I am stalled with the bumper on to more fun.
![]() ![]() Found a hair line crack, I have no welder so I am trying some of this stuff. Had it on the shelf from another project. ![]() ![]() After clean up. ![]() Painted, just have to heat cycle it. I know it will not last but is better than how it looked.
I managed to get it pretty close with some more tweeking. I might just say close enough and paint it.
Lay the bumper upside down on a piece of cardboard and trace one side. Cut that out and use the concave portion to check the other side. Do the same to the body holding piece of CB up under the rear fender.
Found the problem.
![]() Flares are welded incorrectly. ![]() ![]() Explains why one wheel looks like it sticks out farther than the other. I have my work cut out for me when it is time to repaint.
that sux, but I am sure you will come out right on it when done. Good luck!
Shane - 1984 928S |
I did some more checking today and the old bumper did stick out almost an inch more on the p. side. The shape is just more forgiving in apperance.
This is good news, the other bumper was not butchered to fit as I would like to sell this one, it is a nice bumper just not correct for my car. I measured from the inner fender wall to the fender lip. Drivers side is 12 inches, passenger side is 11 3/4 inches. Looks like I will be cutting to get a correct fit.
Update
Cut, fit and glassed. Just waiting for band aid to dry. Then I can remove spacer and finish glassing it.
8 layers of fiberglass, two layers of putty, one layer of glazing putty and a shot of primer. A little finish work and ready for paint.
Prepped my "new to me" Turbo valve covers. Valve adjustment and the turbo valve cover update is next on the list.
Mike, it looks like it is coming right along. Nice results!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
yeah, good job!
Shane - 1984 928S |
Morning update
Thanks guys, Did a test fit and I am happy with the results. It is still off a little, I think the other side shrunk.
![]() Waiting for the 5 minute epoxy to dry in the relief cuts. Then I can finish glassing and move on to final prep work. ![]() ![]()
Help there is a Shark in my garage!!!
![]() UH.... never mind, I just grabbed him by the neck and sucked the life out of him. LOL!!! ![]() A couple of spots to touch up other wise ready for wet sanding, epoxy primer and paint. ![]() ![]() ![]()
Looks great! Are those Rota's with the RSR finish?
Shane - 1984 928S |
