Fidalgo911S's Avatar
Exhaust studs too long. Solution?
Currently replacing the SC exhaust that was put on my '74 prior to me owning it. I bought a set of used '74 HE's with the thin flange. I'd say the exhaust studs are about 3/8" to 1/2" too long.
Do I just stack washers on there or is there a better way?
Nate
Old 03-02-2008, 06:49 AM
Oh Haha's Avatar
Cut them down with a Dremel tool with a cutting disc. That is, if you can get to them easily.
put nuts on first and then remove them after cutting to restore the end threads.
Pacific Blue
Wayne
Old 03-02-2008, 07:25 AM
I was just gonna say, buy new ones.
Old 03-02-2008, 07:26 AM
Engine is on the stand so cutting the studs down will work. I think that's a good solution.
Nate
Old 03-02-2008, 07:40 AM
3.2 CAB's Avatar
Is there any chance of you changing the exhaust out again? Maybe the new exhaust will have the thick flanges??? I always try to keep things the way they were, in case I ever decided to put things back how they were. I would not cut the studs, because I might need them the longer length later. I would not use washers to make up the difference, I would use sleeves, that would make the studs the correct length. Or as another said, get new correct length studs, and if you change to a thicker flange, put the old studs back in, if you kept them, but new studs and nuts would be better. Just a thought.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-02-2008, 12:03 PM
SCWDP911's Avatar
People who have used sleeves for this, are you just using something like stainless tubing. Is there a fairly accurate length to use, or is it YMMV?
Shane
- 1984 928S
Old 03-02-2008, 01:31 PM
Removing the studs, unfortunately is not an option. A couple of them broke when I disassembled the engine and the machinist had to drill out the remaining portion. Even welding nuts on them and using a big wrench didn't work.
I tried sleeves, but unfortunately used a soft material (brass). That took an hour to undo. I like the idea of keeping the extra length. Thicker steel sleeves then. I imagine I'll have to cut them to length.
Nate
Old 03-02-2008, 07:58 PM
Information Junky
island911's Avatar
A stack of washers is the good solution.
Old 03-03-2008, 12:14 AM
