-   -   engine idle while oil cap removed question (http://forums.pelicanparts.com/porsche-911-technical-forum/396096-engine-idle-while-oil-cap-removed-question.html)
Porsche-poor 03-02-2008 04:14 PM
Just finished changing the oil and went through the fill up drive and check procedure. I opened up the oil tank there was only a subtle change in rpm. I was under the impression I would hear a big change. Let me guess a vacuum leak some place else?
mca 03-02-2008 04:37 PM
My RPMs drop pretty significantly when I remove the cap.
I have never looked at tach to see how much it drops but it is a very noticeable change.
It may be best for you to see someone else's so that you have something for comparison.
Car Guru 03-02-2008 04:57 PM
I'm curious too, I checked mine after the last thread on this topic. My RPM barely changes, only a keen ear would tell. Is it suppose to change?
-Ryan
Bill Verburg 03-02-2008 05:00 PM
Yes, idle rpm will change. The oil tank vents into the intake manifold. when the cap is removed it allows more unmetered air to enter the engine. There is a restrictor that reduces the amount of air other wise it would just die.
Porsche-poor 03-02-2008 05:20 PM
So as long as there is a change its ok even if its just slight?
300cd300sdl911 03-03-2008 05:02 AM
Just jumping in ......on both our 911's we have a significant drop in rpm (or at least sounds like it) when the oil filler cap is removed.
Formerly Steve Wilkinson 03-03-2008 05:41 AM
What year 911s? I think that makes a big difference, doesn't it?
300cd300sdl911 03-03-2008 05:54 AM
Both of our's are 1985 - one ROW the other US spec.
Porsche-poor 03-03-2008 07:13 AM
so does this mean that my engine idle is compensated for a vacuum leak else where and it makes not diff if the oil cap is off?
