Porsche-poor's Avatar
engine idle while oil cap removed question
Just finished changing the oil and went through the fill up drive and check procedure. I opened up the oil tank there was only a subtle change in rpm. I was under the impression I would hear a big change. Let me guess a vacuum leak some place else?
'79SC Targa
'2021 CRV
Old 03-02-2008, 04:14 PM
mca mca is offline
mca's Avatar
My RPMs drop pretty significantly when I remove the cap.
I have never looked at tach to see how much it drops but it is a very noticeable change.
It may be best for you to see someone else's so that you have something for comparison.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 03-02-2008, 04:37 PM
Pool Janitor
I'm curious too, I checked mine after the last thread on this topic. My RPM barely changes, only a keen ear would tell. Is it suppose to change?
-Ryan
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
"Wow! What a Ride!"
< '88 Porsche Carrera Cabriolet Sold >
Old 03-02-2008, 04:57 PM
Bill Verburg's Avatar
Yes, idle rpm will change. The oil tank vents into the intake manifold. when the cap is removed it allows more unmetered air to enter the engine. There is a restrictor that reduces the amount of air other wise it would just die.
Bill Verburg
Old 03-02-2008, 05:00 PM
So as long as there is a change its ok even if its just slight?
'79SC Targa
'2021 CRV
Old 03-02-2008, 05:20 PM
Just jumping in ......on both our 911's we have a significant drop in rpm (or at least sounds like it) when the oil filler cap is removed.
Old 03-03-2008, 05:02 AM
What year 911s? I think that makes a big difference, doesn't it?
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-03-2008, 05:41 AM
Both of our's are 1985 - one ROW the other US spec.
Old 03-03-2008, 05:54 AM
so does this mean that my engine idle is compensated for a vacuum leak else where and it makes not diff if the oil cap is off?
'79SC Targa
'2021 CRV
Old 03-03-2008, 07:13 AM
