-   -   Squeaky Front End New Twist (http://forums.pelicanparts.com/porsche-911-technical-forum/396126-squeaky-front-end-new-twist.html)
bobby thomas 03-02-2008 06:20 PM
I have read many of the posts regarding front-end squeak. This is my story: My sway bar bushings have squeaked for a while, particularly when the car is cold. My mechanic used a different kind of bushing (don't know what), so they have been speaking a bit since they were replaced. But, it started to get a little worse. The other day I jacked up the car, and when the front came off the ground (unloaded the shocks) it made a really loud squeaking sound. Since then it has been squeaking like crazy. Any one have other ideas besides the sway bar and ball joint bushings? Note, I haven't tried to diagnose the problem yet. Thanks.
don911 03-02-2008 06:28 PM
My squeek was due to worn out A-arm bushings allowing contact with the top of the torsion bars. Sounded like an old Ford until I replaced with elephant polybronze bushings.
Jeff Alton 03-02-2008 10:00 PM
I think Don has nailed your problem. This is VERY common.
Cheers
bobby thomas 03-03-2008 08:43 AM
Thanks guys. I won't be able to get up under the car for a few days, but now I know what I'm looking for.
stlrj 03-03-2008 09:02 AM
My squeak was due to broken tack welds on the threaded inserts for the 3 bolts holding the front of the A-arm to the pan.
