-   -   Odometer dead but speedometer works (http://forums.pelicanparts.com/porsche-911-technical-forum/39624-odometer-dead-but-speedometer-works.html)
jthwan22 04-24-2001 03:41 PM
My odometer is not working but the speedometer still works. Does that mean the speedometer sensor is ok and I need a new gauge? I pull the spedo out of the dash last night. Everything looks plug in with no loose wires. Any ideas?
1984 911 Cabriolet
Jim T 04-24-2001 03:46 PM
The odometer gear is "slipping" on the axle that it is press fit onto, and that drives it. This is located in the gear cluster inside the speedometer. You of course need to open up the speedo to get to it.
I think there is a tech article on how to fix it somewhere on this site. Alternatively, any of the many speedo shops can fix it for you, its an easy job for them.
[This message has been edited by Jim T (edited 04-24-2001).]
fred hannah 04-24-2001 05:21 PM
i have the same prob., but my gear was stripped, not just lose like the tech article describes. i havent got it fixed yet. its only a little brass gear about half as long as a tooth pick. i cant imagine what that little sucker will cost. i called vdo and they said they could fix it, but that they would not sell me the gear so i could fix it my self, go figure.
Dug89 04-24-2001 05:50 PM
Cha-ching. Never try to reset the trip odometer whilst moving. It will break the gear in the odometer.
Had a friend do this and he had to send the speedo off for repair. When getting it repaired have the shop correct the miles up to cover the miles driven while it was broken.
It is important that the work be done by a certified shop so that the repairs are documented. No sense in making your Porsche less valuable because the odo has been tampered with illegally.
Doug 84 911 ROW
Chris Lovell 08-03-2010 05:39 PM
Odometer first, now speedo failed
My odometer failed a few months ago, and yesterday, the speedometer failed as well. I was thinking the speed/odo unit needs a rebuild but it just occurred to me that I was in the rear seat floor "hatch" yesterday working on the shift linkage. Do you think I disconnected something in there? '88 Cab
CL
86 911 Targa 08-03-2010 05:54 PM
1984 911 Cabriolet
Lots and lots of posts on this subject.
Search odometer gear..........
Hodgey 08-03-2010 05:58 PM
sending mine to North Hollywood Speedo on recommendations from this board and from my ace local Porsche guys at Eurasian Auto in Birmingham........
dshepp806 08-03-2010 06:37 PM
Hands off,...to NHS for repair, I'd say. (as well as a requested speed recalibration)
Best,
Doyle
E Sully 08-04-2010 08:36 AM
CL,
The odometer problem is most likely the common broken gear. The speedometer stopping could be one of the connectors for the sending units wires being loose. They are under the plate by the shift linkage.
rick-l 08-04-2010 11:31 AM
What is with all the guests? Edit: nevermind that is from 9 years ago
http://forums.pelicanparts.com/porsche-911-technical-forum/196987-odometer-gear-replacement-electronic-speedometers-long.html
Chris Lovell 08-05-2010 08:42 AM
E Sully and all, Bingo! Disconnected wire under the shift linkage plate. I loosened this sending wire when I was adjusting my shift linkage. Speedometer works like a champ now. The odometer will need to be fixed by sending to a shop.
CL
Hugh R 08-05-2010 08:45 AM
I've heard that you can fix it yourself. I dropped mine off at North Hollywood Speedometer, they fixed, repainted the dial and calibrated it.
