Gary Peters
Guest
Posts: n/a
Post Removing 3M Spray Glue
I'm just wondering if there are any products out there that remove old spray glue effectively. I'm removing the amp racks from my boot and the install shop had used it to hold on the carpeting.
Any ideas would be much appreciated.
'76 911S
'80 924 M471
Old 04-19-2001, 10:19 PM
RLJ
Guest
Posts: n/a
Thumbs up
Wow! Just today I bought a can of 3M super strength spray adhesive for headliners and carpet and asked the same question. 3M also makes adhesive remover. Bought a can. It has a small plastic squirt nozzle with a red cap taped to the top.
Good Luck
Randy Jones
1971 911
Old 04-19-2001, 10:38 PM
Zendalar
Guest
Posts: n/a
Post
Acetone, thinner, paint remover, although they all are very effective and might remove some paint also
Old 04-19-2001, 11:22 PM
kamikazepilot
Guest
Posts: n/a
Post
Their is a great product that is called "goo gone" it is for just this type of task!
As always test it in a out of site area first.
Get in, Sit down, Shut up and HOLD ON!
1978 911 SC
Old 04-19-2001, 11:28 PM
Obin Robinson
Guest
Posts: n/a
Exclamation
Goo Gone will be the safest. If it doesn't come out then try paint thinner. I just spent a few days stripping the soundproofing out of my 924 and i used both Goo Gone and Paint Thinner. the Goo Gone is nice because it is not as toxic. if you have to use Paint Thinner, use the odor-free stuff.
good luck!
obin
[This message has been edited by Obin Robinson (edited 04-20-2001).]
Old 04-20-2001, 03:58 AM
David McLaughlin
Guest
Posts: n/a
Post
My favorite glue and sticker remover is WD40. Spray it on the residue and wipe off with an old towel. You may need two or three applications before it's all gone, but the stuff works great. I just removed the vinyl roll bar covering using this meathod. It revealed 31 year old yellow paint that looked like it was sprayed yesterday. Now to convert the rest of my orange car to that color and quality.
Dave
1970 914-6 (soon GT)
Old 04-20-2001, 09:33 AM
Charlie Moore
Guest
Posts: n/a
Post
A product called "Lift-Off" works good too. It comes in several different varients depending on what you're trying to get off.
Old 04-24-2001, 02:24 PM
stormcrow
Guest
Posts: n/a
Post
I generally use charcoal lighter fluid. It's oil based and it won't remove the paint unless you rub really really hard.
Old 04-24-2001, 07:44 PM
