			 Tired Member
				Garage planning
			I am planning on remodeling my garage and I think I have settled on my plans but wanted to see if anyone had experience with the two companies I plan on purchasing product from.
				So, anyone have experience with this company? http://www.americangaragefloor.com/ Or this one? http://www.garagestoragecabinets.com/index.html
	Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec  |
			No experience with either company but you may want to do a search on garage floors here.  The costs for those floors on that site are astronomical compared with the coast of ordinary vinyl 12x12 tiles availabe from Home Depot.  I know some Pelican used black/white tiles except they used a 2'x2' pattern instead of the 1x1 as it is too busy. There is a very, very clean picture of the install comeplete with a nice white 930 parked on top! WOuld probably save you enough to "go long" on the nice shop cabinets off the other website.  Best of luck and please post "before" "during" and final pictures.
	Dan in Pasadena '76 911S Sahara Beige/Cork  |
			Try www.garagejournal.com . I stumbled upon it but haven't really looked into it. Seems like a good starting point.
			 MBruns for President
			Glenn try http://www.gregsmithequipment.com/Floor-Tile-s/26.htm
			I have their floor and have been very happy with it ![]()
	Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2  |
			 Livin' the Dream
			If your are looking to save money and are interested in doing a little work, I bought these plain wood cabinets from Home Depot (or maybe Lowe's) for $65 each and then painted them and added the steel panels and knobs.  They are 36 x 30 x 12.  I am very happy with the price and the results, but if you want different sizes, there are many different ones to choose from.
	'84 911 Carrera  |
			Jeremy,
			Is that a hot water heater? I don’t care if your hot water heater is “within code”, get it out of your garage! The life you save will be yours and your family. The car you save will be your Porsche. Are those hot air & A/C ducts to a furnace and air conditioner in/under your house? There is another potential problem. Concerned, Grady
	ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50  |
			 Tired Member
			I'm looking at $2.63 per square foot for the flooring.  I've got 400 square feet to cover.
			I considered the tile but I am concerned about ease of cleaning. With the roll floor, I can mop it or hose it down and don't have to worry about stuff leaking through the cracks. I'll have to look at Lowe's and Home depot to see if I can find cheaper cabinets. I really would like a factory finish instead of having to paint them. Grady - that's pretty much the way they build houses in Florida. The water heater, air handler and all that cr@p goes in the garage. You don't find too many basements here.
			Lowes have the gladiator cabinets -  that's what I ended up with.  The water heater is electric.  and I've had one in the garage for the last 20 years - never had an issue -- -  the air handler (2) is above the drywall in the garage -  In Florida, the least of my worries is an exploding water heater. The tile is really easy to clean -  it was nice because basically I cleaned the floor then put it down -  no other drama.
			I was in that range too - I think they had a special of 2.29 on ebay and matched that price when I called the store correct.
			OK, I think the order of design concerns probably should be:
			1) SAFETY; (probably 2, 3 & 4 also). Garages have gasoline in them – in your cars and otherwise. Gasoline is probably the most dangerous substance we normally ever come in contact with. The fumes are highly explosive so there needs to be the ability to vent the garage to the outdoors. There should be no possible way for fumes to get into the house or near an ignition source. Of course there are usually all sorts of other chemicals. The floor should have a slight grade to the overhead door so leaking gasoline can exit the garage. If you have a floor drain, it should not go into your sanitary sewer. Fume, CO, smoke detectors and sprinklers should be mandatory. Of course lifts, floor jacks and jack stands also present safety issues. 2) UTILITY; the garage has to work for its intended purpose(s). Most aren’t a dedicated Porsche-only home workshop. The ‘other’ considerations need to be addressed; bicycles, ski rack storage, golf clubs, kid’s science projects and ‘honey-do’ projects. Part of this is your access to electricity, compressed air, a venting system, parts cleaner, pressure washer and most important lights. You can’t work on what you can’t see. I’m in favor of a solid, very light gray (almost white) floor and lots of overhead lights. The air compressor should be somewhere else. They are all noisy and obnoxious to be around. Through-the wall air conditioners, heat pumps and heaters work well and prevent any exposure to an open flame. Storage is always an issue; you can never have too much. This is sometimes called “The tyranny of things.” Things expand to consume all available space. Garages are also typically used to park your (and spouse’s) cars. ![]() 3) CLEANING & CLUTTER; It is useful to have just about everything either on wheels, casters, hung or cantilevered off the walls. This will make periodic scrubbing the floor not so much of a chore. This also allows you to clean out the stuff that tends to accumulate in every available space. 4) COOL; part of this is to show the toys. The refrigerator disguised as a SnapOn tool chest helps. So does the HDTV. The WiFi connection to Pelican is a necessity. A few vintage (reproduction) Porsche 917 racing posters complete the touch. 5) CHANGABILITY; too many ‘built-ins’ make it more difficult to adapt to your changing needs and projects. 6) COST; few want to waste money. Being thrifty allows many to own several projects. Many solve this by having built ‘unfinished’ space and then DIY (with the door closed). 7) RESALE; it isn’t wise to build a ‘white elephant’ that will reduce the value of your house. 8) NEIGHBORS, COVENANTS AND ZONING; ‘nuf said. Best, Grady
I am tuning into CNN right now as I expect most of the state of FL to blow up any minute now.   If it does then you can't say "Grady didn't tell you so."
	1982 SC...Guards Red + Linen  |
			 Tired Member
If I were building a garage from scratch, I'd keep all that stuff out.  But since I'm not I will have to yield to budget and practicality concerns instead of Grady's much respected safety concerns.
			 Tired Member
 1) I am working with an existing garage so I am limited on the structural changes. It is really just a remodel. 2) I'm focusing on lots of storage and clear space to park/work. I'll be adding lights and have selected a gray (not so light) floor color. 3) That is a big driver of this project. All cabinets will be 10" off the floor to allow for easier cleaning. And lots of cabinets to hide the mess that lives in the garage now. 4) I think neat and tidy is a cool start but will add appropriate decor as time goes on. 5) I think I've got that 6) Total budget is in the $2,500-$2,700 range 7) lots of usabe storage space, nothing gold platted about it. I'll post my layouts in a little while.
			 Tired Member
			Plan view (the garage opens to the east)
			![]() south side ![]() North side ![]() west side
			 Matt
			you may think this is insane, but I had a friend who put in porceline (sp?) tile- he bought it on sale for .99/ft at Home Depot- what a fantastic surface! not too slick, easy clean-up, no tire marks from hot tires, easy cleaning, very durable and certainly enhanced house value...
			Most garages are square sided, so laying is not too hard. Might be worth hunting around for a deal....
	79 SC Targa 87 m491 Targa 73 BMW 3.0 CS 73 BMW R75/5 88 BMW M6  |
			 Tired Member
			 - Self Moderating -
	Tim Present: 57 Intermeccanica Speedster Ivory on Brown Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan  |
At least they got the GAS hot water heater off the floor.  It will take just a little bit longer for gas fume to reach the pilot light of the Hot Water Heater.
			 Tired Member
			So.... back on topic.
					Anyone have experience with the two companies in my first post?
