davis911s
Guest
Posts: n/a
Question Grounding wire on engine behind altenator??
This wire that is located on the top of the engine just behind the altenator housing it attaches at one end to the engine through bolt, where does the other end go?
Shawn
Old 04-25-2001, 12:37 PM
nhromyak@yahoo.com
Guest
Posts: n/a
Post
I am not sure, but I think it goes on the case of the alternator.
What type of connector is the ground wire where it attaches to the alternator?
Is it a spade connector? If so there should be a mate for it on the alternator (should be a ground).
Or is it a round type connector?
If this is a round type, I think it goes on one of the shroud bolts.
Also check for a B- post. This might be it too.
I would have to look at the manual to be sure though.
Sorry. I am just not sure. I wanted to add my .02 though
Nick Hromyak
'85 Carrera 7 & 9 Fuchs
Havin' Fun in
Sacramento CA
Old 04-25-2001, 01:59 PM
AMG Hammer
Guest
Posts: n/a
Post
Yes, it goes to the Alternator. If you are looking at the Alternator from above while it's in the fan housing it should connect to the far right connector on the Alternator. You should also have a smaller grounding wire connecting to this same point.
Old 04-25-2001, 02:42 PM
davis911s
Guest
Posts: n/a
Post
Thanks so much yes hammer your right I actually found it in one of the pics I took when I disassembled the engine. It was in the corner of a pic. I thought I took lots but now that its going back together I wish i hade taken more.
Shawn
Thanks again everybody
Old 04-25-2001, 02:48 PM
