Engine Tin Color
I notice that the engine tin covers have been different colors through the years. I imagine its due to displacement, but I wonder if the color should match the year of the car? or whether the engine color should match the displacement?
The engine TIN is all a semi flat/semi gloss black...I think you must be talking the fiberglass fan shroud that directs the cooling air over the engine?
In which case...I'm not an expert...but I have noticed differences depending on MY and displacement. I have a red one on my 911SC 3.0 I remember a yellow one on a customers '72 911T I'm sure others will chime in. I know I have seen green, black, and yellow on '77 and earlier engines. Any experts on the fan shrouds? |
Red = early S, RS
Green = early E, or CIS based 2.7L 911'S' (which isn't really an S) Black = later years natural (translucent amber) = R and some other racers, 904? |
Thanks RWebb! I knew someone would chime in.
Coop |
yup, engine shroud. That's what I meant.
So if I have a stock SC, then it is red. When I modify the 3.0 & put in to my 69 E, is it more correct to go with green or translucent? |
green for an E (but you won't really have an E motor, will you??)
it is a special color green too... paint will never replicate the true color & patina of a real FG green engine shroud, but can look quite nice search for the threads on exactly how to prep., etc. |
That's why I thought a race colored shroud might be more appropriate. Though I like the sleeper idea better. Remove the 3.0 badge on the engine grill now, put a green shroud on and then watch newer 911 owner's eyebrows raise as I pass them and pull away . I always get a chuckle when the Boxer owner's wives say "that's such a cute little car". Then when I fire the engine, the husband's ears perk right up. hehehe:D |
| All times are GMT -8. The time now is 07:19 PM. |
